brus brother
    43
Everything posted by brus brother
  1. Unless of course a non Subie tech actually drained the AT fluid and unwittingly overfilled the oil. I don't recall if you specified manual or auto transmission. If automatic, for peace of mind, check the AT fluid. If it is only a case of overfilled oil, I have also had Subie techs overfill my oil (generous fellows) and simply took it back for them to adjust. Lesson learned... check your car after service. As to a brake job at 30K, some drivers ride the brake and can result in early wear however, before I started doing my own brakes, I had "aggressive" mechanics sell me brake jobs long before actually necessary. Lesson learned... learn to do whatever you feel comfortable with and you'll have no one to blame but yourself.
  2. Looks like Howard's broken clock will be part of a Fresh Air Fund summer vacation in Alaska! Cheers to Cougar for his housepitality.
  3. I know whay you mean... as soon as I finish labelling my 8 Track tapes, I too intend on moving up;)
  4. Tried it all on my 2000 Legacy GT, cooler plugs, higher grade gas, Scientology...no difference. It's just another sound of summer. I get the feeling there is a missing link in the sensor department that would adjust for air and humidity...
  5. I know, I know... you accidentally drained the AT fluid and have now overfilled the oil. Additionally, you drove 200 miles home for lunch and cooked the transmission. Your only option is to make an appointment with Pep Boys to replace the transmission and reset the rocker switch on the steering column to the ON position so they can replace the battery while you wait.
  6. If you've already decided to send it to the trash heap, what can it hurt to open the bugger and see what's wrong? You may get lucky and find that simply powering off the unit completely will reset a memory or you may find a disc jammed up. Remember, it's already broken... you can't break it!
  7. Common problem is using home made cds with paste on labels. If you open the unit and discover one such cd, the unit may not yet be toast.
  8. If your 1990 car ran well in previous summers and now it's not, likely carbon buildup is culprit, unless you got a bad batch of gas. Obviously new plugs is a good place to start but then conisder top engine cleaner.
  9. I personally wouldn't use aftermarket for an issue as sensitive as HGs since even SOA original spec failed. Likely aftermarket followed the original spec if anything. I believe there is a difference with the redesigened ones though. Did you have the heads checked by a machine shop for warpage?
  10. 8 years. Talk to the dealer. They don't mind doing work if they can justify it. They are paid by SOA and it's more work for their shop.
  11. I agree but start off by being nice. (see my response to your other post)
  12. http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm This takes you to the NHTSA site. Your recall was a voluntary recall and good will warranty extension. I would call Subaru of America and plead your case. State that you had smelled the anti-freeze for some time (over a year? and 9,000 miles ) but since you never noticed any puddles (the leaked fluids would be evaporated on the hot engine) you didn't make much of it. Perhaps they will extend their good will (your family has been loyal Subaru owners for many years) they will at least share the expense with you. Be nice. You may be surprised. Good luck. PS If you are the original owner, or registered with SOA when you bought the car used, you should have been notified of the recall. The warranty extension only applied to those who took part in the recall and added the stop-leak to the coolant system. If all else fails and you can't afford an immediate repair, you might want to try their "fix" and add the stop leak. Others might warn against it as potential for clogging the radiator but this is what SOA did to all of the vehicles in the recall.
