45
Everything posted by brus brother
pinging?
brus brother replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If your 1990 car ran well in previous summers and now it's not, likely carbon buildup is culprit, unless you got a bad batch of gas. Obviously new plugs is a good place to start but then conisder top engine cleaner. -
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm This takes you to the NHTSA site. Your recall was a voluntary recall and good will warranty extension. I would call Subaru of America and plead your case. State that you had smelled the anti-freeze for some time (over a year? and 9,000 miles ) but since you never noticed any puddles (the leaked fluids would be evaporated on the hot engine) you didn't make much of it. Perhaps they will extend their good will (your family has been loyal Subaru owners for many years) they will at least share the expense with you. Be nice. You may be surprised. Good luck. PS If you are the original owner, or registered with SOA when you bought the car used, you should have been notified of the recall. The warranty extension only applied to those who took part in the recall and added the stop-leak to the coolant system. If all else fails and you can't afford an immediate repair, you might want to try their "fix" and add the stop leak. Others might warn against it as potential for clogging the radiator but this is what SOA did to all of the vehicles in the recall.
There's been a few discussions on this site for drain and fill vs. tranny flush. It appears that doing the math, you would need to drain and fill 6 times in order to replace ALL of the tranny fluid from all the nooks and crannies that would otherwise remain and simply be diluted with each subsequent drain and fill. At that rate, the cost of doing 6 drain and fills yourself is a wash with getting a flush done by a shop.
Once you get the judgement, you can sieze wages and freeze bank accounts Any cost of doing so or using a marshall is added to the judgement. P.S .employers don't especially like marshalls showing up at a place of business and then again, tying up someone's bank account usually gets their attention since they can't withdraw money (they don't realize this until they've deposited a check or two). The court works. Just stay within the statute of limitations, be professional and prepared and follow the steps.
Are we sure it is a HG leaking oil? That vintage leaked coolant externally as I remember and the replacement HG would have been covered up to 100K/8 years. Is it possible that the valve cover grommets around the spark plugs are the culprit? This is a common problem with that year. If it is a HG leak, is it possible that someone put some "stop-leak" in oil? Is the warranty transferable? How much of a headache can you tolerate? Ask the inspecting mechanic to demonstrate where the leak was... was the engine cleaned since his inspection?
For those of us on the east coast try SubaruPartsForYou.com That is the online cheapo parts department of Dan Perkins Subaru in Milford CT. Very informative and great service. You can actually do a walk in and buy. Ask for Anthony or John and mention this site. You might also do a printout of any of the online sites and ask for a pricematch at your local dealer. The prices are basically what they would charge any repair shop so there is still some profit for the dealer.
OK call me a Nipper-ite but I have to agree. Don't muddy the waters by trying anything! Take it back. If you have documentation that admits to possible incompetence, all the better but you have the right to have it done correctly. The mechanic should be given the opportunity to repair it OR refund your money and refer you to a competent repairman. If all else fails, notify him IN WRITING and give him a set time to respond, say 2 weeks, and then take the car to a reputable repair shop, document the repair and sue the original mechanic in small claims court. It's a relatively simple process but you need to make sure that you can't be blamed for any bit of shared liability by tinkering around with it yourself... you are not an expert in the eyes of the court. I just took note of your location so while it might not be called small claims court in Ontario, there must be a similar venue.
