46
Everything posted by brus brother
I used a company called Dent Wizard and watched them work. The techs use a series of flat pry bars that they slip down inside the door and finesse the dent out working from the edges inward. Obviously, if you can get at the dent from inside the door panel you should be able to massage it out if the paint hasn't been cracked. Go slow... the fastest orchestra isn't alwys the best!
I used a company called Dent Wizard and watched them work. The techs use a series of flat pry bars that they slip down inside the door and finesse the dent out working from the edges inward. Obviously, if you can get at the dent from inside the door panel you should be able to massage it out if the paint hasn't been cracked. Go slow... the fastest orchestra isn't necessarily the best!
Common things happen commonly... That having been said, I had a 94 with gas smells and it was in fact as Skip notes, the corroding filler pipe right iniside the rear wheel by the filler tube. There is a "protective" shroud that covers the lower part of the tube. It traps mud and crud and is just the right environment for rust. SO, even if your problem is related to the cannister under the hood, get under the car and flush the crud out of this area.
What I hoped to infer was that while the suggestion to change the PVC was a cheap and easy fix, by rattling the valve, you might also be able to immediately differentiate whether the PCV was the problem and not just another of many things that should/could be done. By the way John, your ! key seems to be stuck or dragging.
OK Billyboy, it seems that if the recall campaign was performed for your vehicle, just drive right to Subaru and have them replace the HGs. The car is warranteed not the owner. The warrantee is transferrable. It's not necessary to indicate all of the other "information" about things that were done since then. Tell all that sort of "information" stuff to your spiritual counselor. Do you really think SOA is telling you ALL of their "information"?
The dreaded head gasket leak on that year model leaks from the rear cylinder on the driver's side. Make sure you had the coolant additive done under the extended warranty which is good for 8 years and/or 100,000 miles. If you didn't have the stop-leak additive, then go get it FREE. After a few weeks, if it still leaking, go back in and report the leak and let SOA replace your headgaskets FREE. If it is leaking, it is also doubtful that the stop-leak stuff will work in the long run.
WO, Thanks for the offer. I will PM you.
Anyone know where I can pick up a 360 roof panel that hasn't been in a rollover. A buddy has one with a few cracks and is getting lazy about repairing it. Tan would be lovely and could you deliver it please? BTW nice to see ya around Moosens and Nipper, what are you doing over here?
