43
Everything posted by brus brother
Like the Nipster said, be nice. Loosing the dogs on them immediately will only make them run for cover. Discuss with the local dealer that you have noticed the smell of antifreeze for QUITE some time but never thought to check since you were quite certain that SOA's "fix" had been taken care of under the approved recall. You had thought that the ticking time bomb had been disarmed, not just equipped with a slower burning fuse or delayed timer! NEVER would you have any reason to doubt that their "fix" was anything but the guarantee of reliability that you have come to expect of a fine manufacturer like Subaru. Then immediately go and brush your teeth after talking such s%^t. PS: Where in SE CT are you? I use Dan Perkins in Milford and they've gone to bat for me over the years.
Use the Search function. Clunk sound at slow speeds as when turning into a driveway over a small bump? This was diagnosed as hydraulic knock on my 2000 Legacy and I was told that it was present in many previous years. There is a kit that ? fixes it by installing a damper in the power steering fluid line. It's certainly less problematic than the dreaded torque bind.
Look carefully for source of leak. Removing the timing belt cover should make it easier to see if the water pump is the culprit. Can you keep an eye on the radiator and hoses to see if they are the culprit. While this involves some "down and dirty" time of your own, this sort of diagnosis may remove the guesswork. There is also a dye that can be added to the coolant that can be detected under UV light.
