Everything posted by brus brother
Grounding Mod Re-visited **56K Warning**
brus brother replied to Lawsonmh15's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK you shamed me into inspecting my grounds. I found the connection to the engine and firewall alright but the split wire off the neg terminal where it grounds to the fender was pretty crusty. Wire brushed and reconnected. Should I coat the exterior of these connections with dielecric grease? I have been having some dimming of lights when braking and will report back if there is any change.
Beginner Mistakes
brus brother replied to xcracermg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you remove/open the air filter box or any other of the related components to access the plugs? You may have just not connected them properly. This happened to me and made the car sound "throatier". Also, if there has been a drastic change in performance after doing the work, you may have disconnected a vacuum line.
Piston Slap
brus brother replied to bkcraun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like you are still under warranty (04 with 24,000 miles) . I would get thee soon to a dealer and pitch a bit@h.
05 Outback radio/HVAC lights out?
The lighting for the radio and HVAC went out for about 3 days. The radio and HVAC worked fine, just the lights were out. All other dash lights worked as expected. After a few days, the lights became operative again. I documented this with the dealer but they were unable to reproduce. Anyone else have a similar problem or idea of what posssessed my car?
A dent/hole about the size of a penny
brus brother replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUse your insurance. Explain what happened.
05 Outback Headlights Kaput
Standard setup. I don't know if it was HID or not.
First one went last year and was replaced and my second one went out last week. There is a bulletin or recall since the first one so now they replaced both bulbs. Rear driving bulb died last month but I suppose that's just coincidence... for now.
Your favorite parts suppliers
brus brother replied to DaveT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subarupartsforyou.com Right in your own back yard in Milford CT. Genuine Subaru parts at discount.
I'm home...
brus brother replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Nipper saga included replacing the engine before making it back across the Donner pass.
Window Gusset? '99 Forester
brus brother replied to jon38iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you can do the repair as described above, I would suggest you try it and if it works, either return the item or put it on the shelf until you really need it. The less you take apart, the less parts you can lose, break, reinstall incorrectly... As I recall, the Subie tech explained the repair as pinching the outer and inner aspects of the triangular piece together. Aside from closing the door using the glass (you don't), the distortion can happen when the passenger (plus size) is trying to exit the car in a tight parking spot and pushes against the glass.
I'm home...
brus brother replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX...2 engines...
Stuck heater button 95 legacy
brus brother replied to ogiesdad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you take the module out to clean it, check wiring harness, caress, cajole, plead, wiggle, tap it gently with the heel of your shoe? You can always get a replacement but... is there a board member that could help with checking the harness i.e. jump it and make sure that it's not other than a bad switch module?? Cougar? Chief Tim? Nipper? Car 54 where are you?
brus brother replied to ogiesdad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDistant memory of my 90 Loyale was that the buttons were vacuum related. On the 90 Loyale I had somehow disconnected a small diameter (same as windshield washer hose size) vacuum hose in the engine compartment on the passenger side just in front of the windshield. I can't remember if this stopped the buttons from working as you described or if the operation of the unit become non-functional until I reconnected the hose.
I have spark, compression, fuel pressure, but it still doesn't start
brus brother replied to rysbrnr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a trailer hitch and tow (flatbed of course) another sube behind you and you'll never want for spare parts;)
brus brother replied to rysbrnr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo, is the brass cannister thing part of the fuel pump? I thought I read that your problem persisted even with a new pump in place??
2000 Outback mechanical issues
brus brother replied to leinad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's because you are from Hawaii. The original poster is from New Joisey... bahdahbing!
brus brother replied to leinad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOther than the check engine light, were there any other sympotms with the TPS?
Nipper hits the 5000 mark
Ole Nippy boy just reached his 5000th post:clap:. I am trying like hell to catch him by posting such as this and so as to not be banned to the Off Topic page, let me just say... torque bind, head gasket, KN filter and to be politically correct, I am Brus Brother and I approve this message.
Torque bind and Tran luid light.
brus brother replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe Nipster is just miffed because nobody noticed this was his 5000th post:clap:... no ataboys, no cards, fanfare, squat... after all I've done for you... so... ATABOY, GOOD JOB, BEEN SWELL, COULDN'T HAVE DONE IT WITHOUT YOU, HERE'S TO 5000 MORE! Now, back to work! PS when I first read TB expert, I thought you were talking about tuberculosis. Thank God torque bind isn't contagious.
Victory... (sad follow-up)
Fortunately I've never had the torque bind problem but from following posts, it would seem to make sense to try drain and refill with regular ATF a few times before you bring in the big guns.
B9 Tribeca stinks!
brus brother replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYikes... the grill on that Ford is about as innovative as the robot from The Day The Earth Stood Still released in 1951 (See 1 Lucky Texan's avatar - Post #26 this thread)
B9 Tribeca stinks!
brus brother replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAND they both appear to have 4 wheels!
B9 Tribeca stinks!
brus brother replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEr... yes she did (same color) and it is in my driveway. I love the styling and balance of the 05+ Outback design. Not much of a racer boy anymore so I didn't go for the hood scooped turbo (premium gas too:-\ with the turbo). It reminds me of the Lexus SUV but pleasantly toned (and priced) down.
no warranty, your problem
brus brother replied to filarico's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess it's best to lather up your best Texan drawl for this, then hurry home and brush your teeth after having talked such sh*#.
brus brother replied to filarico's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat else to tell them?? Oh, yes, I forgot, you should tell them to... FIX THE EFIN CAR! Seriously, you have been told to piss off and you think you need to be nice? It is now as it was while still under warranty their responsibility to diagnose and fix the car. Bring any service records or documentation with you when you meet the rep. If you haven't already done so, create a phone log (to the best of your memory) to go along with your service visits to show that you are serious about getting satisfaction.
