45
Everything posted by brus brother
Once you have the door panel off to repair the window, there is actually a TSB (tech service bulletin) for repairing the sagging weatherstripping. I think they have a set of clips. Do a search on here for leaking sunroof and leaking lights. These issues have been covered a few times. The SEARCH function is your friend. All in all, the issues presented seem to be minor issues that should be worthwhile fixing and 200K+ seems plausible. Go to NHTSA.gov and check out the service bulletins (about15) and recalls( about 4).
If you look at the first page of the New Gen site there are a few sticky posts. The first is FAQ. This contains information, such as the very thorough write up in this post, that has been addressed with such eloquence that by posting it in the FAQs prevents such stalkers as Nipper, Cougar, OB97 and many more from developing tunnel carpal syndrome from retyping the same information over and over and over... did I say over and over and over...
It's happened to a friend's car a few times now... going uphill in a 96 Legacy (150,000 miles) the car stalls out. Pull to side of road. Turn car off few minutes start and all is well. Any suggestions? Car has had fairly routine maintenance. Where to start?? There is a post about failing ignition relays but didn't seem isolated to uphill conditions.
It is a common issue with the 2000 AT. Apparently the delay shifting is a result of an internal seal not functioning properly and preventing rapid buildup of pressure. My AT was replaced while under warranty. I don't know if a shop would repair as compared to SOA replacement policy instead of their techs fumphering around all day seeing IF they can figure the problem. Go to the NHTSA.gov site and check under MY 2000 for a TSB on delayed engagement.
I had a similar problem with my 2000 Legacy. My fix was fairly simple (but I am pretty tall). Open the car door and stand on the door sill. With the glass open on the sunroof, you should be able to visualize the sunshade and how it sits in the track. Some gentle wiggling and persuasion and ...tada. I have since been more cautious about pushing the shade forward and back without pushing up.
Had a similar problem on a 91. Filler tube has a "protective" shroud at a J-bend down low and just next to the tire. This shroud traps dirt and moisture and eventually causes pin holes as the metal thins out. Pull the shroud back, clear away the caked dirt and you may see gas seeping through tiny holes.
Tires
brus brother replied to Bo13mwz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Just yesterday I got 4 Kumho Solus tires from Tirerack.com after two sets of Dunlop A2 tires that were noisy and never came close to 60,000 mile rating (replace at 25K). Kumhos are noticeably quieter and handle nicely. Will have to wait a few months to speak about ice and snow performance but a few board members spoke highly of them and they were rated pretty well so for $65 each compared to $110 for the highly acclaimed BFG triple track, I thought I'd give them a try. If you see me in a ditch this winter then go for the BFGs. -
Saw this while having my tires mounted todayt. Located in Stratford CT. 88 GL 4WD Hi/Lo Manual 170K miles. Mechanic was taking parts off for his dad (alternator/window motor/instrument panel/ most lights and lenses shot) but said tranny and engine were sound. Needs clutch. Can't drive but you might be interested in grabbing tranny/engine etc. for a song or two. PM me if interested in other details and I'll put you in touch with the owner directly. The mechanic doesn't want to bother much with it so hurry.
You are in Pa. Try DiscountParts.com. They are the online venture of Liberty Subaru in NJ, maybe close enough to keep shipping down. When you call Liberty, ask for the Parts Department and then specify the "discount parts" price. It's basically the same as local mechanics would pay. Jamie aka SubieGal on this site (search members) is very knowledgeable (and a major hard driving babe;)) affiliated with a west coast dealer and in CT. we have subarupartsforyou.com. The discounted price makes it real easy to use genueeny Subaru parts. Put an order together for plugs, wires and filters and no tax covers shipping plus great prices.
