43
Everything posted by brus brother
OK drove from CT to Maine to see daughter and had everything ready to change oil and filter on the 19 OB. Due to the additional underbody cladding, the oil drain plug is tucked WAY up inside a 5x5 opening and makes a friggin' mess as it spurts out. Seriously considering a Fumoto valve as it is protected in the recess and a hose can be attached to direct the oil. I can confirm that it is a 14mm bolt and can ALSO confirm that it uses a smaller crush washer than the ones I've used for years on Subie oil and tranny plugs and that if you use the older larger washers, oil WILL leak. Don't ask me how I know.
Found out that certain models and years (my 2019 OB being one) came with a 14 mm drain plug that is made of soft metal that can easily be rounded over. Warned to proceed with caution and best to use a 6 point socket and not find an SAE "equivalent". Some dealers have learned to replace them at the first oil change but apparently not mine? The car is with daughter in Maine and I'm heading there next week with both 14 and 17 mm 6 point sockets in hand. Hold my ankles, I'm going in!
Bergerb
brus brother replied to Bergerb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I think in 2001 generation you can use a spacer to back the 2nd O2 sensor out of the stream if you are getting P0420 code. Seems you have done everything possible. Are you using genuine subaru parts? Check out Cardoc on subaru ouitback forum. Here If you give him live streaming data, he often helps with diagnosis where repair by wallet has failed. There are 2640 posts on this thread so, you are not alone. Have fun reading. If you want, i have one of the drilled out spacers that I can mail to you. I sold my 05 OB after driving for 8 years with the code and sliding through emissions with a trick or two. The spacer wouldn't work on the 05. -
Changed lower control arm bushings (genuine Subaru) and front and rear sway bar links (Moog with zerk fittings) and the suspension is now as quiet as new. No need to start removing shocks to evaluate top mounts (necessitating realignment). Now to tackle the noisy exhaust. Used high temp furnace caulk a few years ago and might be time for another coat.
The beauty of having your own code reader is that you can do the driving sequence to get the systems "ready" and then scurry over for the inspection. Where are you located? Are you following the below procedure? Do you have a code reader? I will be in Milford tomorrow late afternoon. PM me if you need to try my reader. It's an older version than the one i linked earlier but it will do what you need which is to erase the codes and then verify systems ready after following the below procedure before you go back for inspection. Check the price of the part you are looking for at SubaruPartsForyou.com and realize that if you order online you can pickup in Milford without shipping charges. Often just as cheap as AZ or Advance.
If the cap is on tight, then get new Subaru gas cap. Subarupartsforyou.com is located at Dan Perkins dealership in Milford. Order on line, wait for confirmation and then pickup at counter with no shipping cost and online pricing. use code reader/eraser like THIS erase codes then do the sequence for setting system readiness. It's posted here somewhere. I think here in CT we can get away with one "not ready" and still pass. I had the P0420 through 4 emissions inspections by clearing the code, doing the dance and then straight to testing site.
2008 Outback. 130K miles. Rattling over bumps. I see that the lower control arm bushings are shot. Is there a way to distinguish between sound of those failed bushings and failed shock top mounts? I am not doing the repairs myself. Thinking I'd have them do the control arm bushings first which would not necessitate realignment and then if rattling persists, do the shocks? Mechanic is also suggesting the shock/spring loaded assembly instead of just the top mount (less labor to swap out the assembly than replace top mount?) If so, is Monroe a decent brand?
