43
Everything posted by brus brother
Is it your wallet that is being flushed and drained? Why don't you wait until you see how they treat you over the latest "work" to decide if you need such "premium" service going forward. As an earlier post questioned, it sounded from the description that you needed valve cover gaskets. This relatively simple and inexpensive procedure would not have necessitated removing the engine or doing the head gaskets.
Check out PartsTrain.com. I've ordered mirrors before and where the dealer wanted $100+, aftermarket was about $25 NO JOKE and it fit great. They always have a $5 coupon off floating around the website. Call them and give them whatever part # is specified by SOA. This is a legit source. Comes well packaged and wrapped in a felt bag... felt bag is suitable for regifting at the holidays. P.S. Electric connector was right inside that trangular area I mentioned earlier.
The easiest way to remove it is to drive even closer to whatever chipped it in the parking lot. OK enough wise cracks, if there is a triangular piece on the inside of where the mirror meets the door, gently pry this loose and you will see 3 nuts that hold the mirror on. If there is a speaker there, remember how the nuts attach to the speaker. Diassemble and reassemble. And remember... don't pay retail!
Nippy, can I get one of these mine sweepers as an option on my 05? Seriously, there are defects in anything made by man. That having been said, a neighbor's 05 turbo OB was in the shop within weeks after purchase, so often and for so long that SOA gave him a brandy new car, paid for his rentals and extended the replacement car's warranty to 6 year 100,000 as a good will gesture to assure him that SOA believes in their product and acknowledged that his experience was an aberration. You have nothing to lose by asking for serious consideration. The warranty is a reasonable request (I got one for free in settlement of a similar dispute) since if they really believe in their product, it should cost them nothing and buy back your confidence:headbang:.
Do a search here. http://www.ultimatesubaru.org/forum/showthread.php?t=59345 My 2000 went limp this summer. With the help of the site I went to Walmart, bought a recharge bottle of gas and the hose assembly total about $20. The hose assembly has pretty clear instructions as to what to hook it up to and how to recharge. My car isn't here right now but I think that the low and high pressure connections on the AC have different sized couplings so as to make it fool proof when connecting the recharge unit. 15 minutes of my time... cool!
My thoughts exactly. After you try Nipper's tire rotation suggestion, and if there is no change, if unsure, switch pads and rotors from one side to the other and if the vibration follows, either the new brakes/rotors weren't bed properly or possible manufacturer defect. I know it takes time but this diagnostic test is cheap enough.
The TSB
brus brother replied to jasonwal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Or check out http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm This is the National Highway Trafffic Safety Administration listing of TSBs by make, year and model. If you go to the home page, there is other information on recalls and registering safety issues into their database. -
Hopefully the mileage and months were good otherwise your climb is uphill. While you can say you did the oil yourself at every 250 miles, there is less wiggle room when it comes to a clock or calendar. Warranties are meant to absorb some liability but beyond a compromise for customer relations, they needn't allow much consideration under the "agreement". Hope you slid under the limbo bar.
WARNING After you've sorted out the problem, take heed. I know da Bronx is da Bronx, but apparently you can not only get a ticket for parking in front of a fire hydrant but apparently you can also be ticketed for improper use of flashers?. At least that's what the ticketing officer was kind enough to explain to me as he wrote only the one summons for me to which I replied, using my best "Queens" English, er... thank you kindly officer.
