Everything posted by brus brother
USMB 1, Crappy Dealership 0
brus brother replied to czyivn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- Low Brake Pedal - 2001 Forester L
brus brother replied to forester01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.scoobymods.com/forums/showthread.php?t=182 The above is step by step and sequence for bleeding Subie brakes. Check the manual but I think there is fluid that is compatable with either.- Low Brake Pedal - 2001 Forester L
brus brother replied to forester01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBleed the brakes.- Legacy 1990 passenger front door locked
brus brother replied to stavan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom the school of tap it gently with the heel of your shoe...- driver's window wind noise fix
brus brother replied to gbhrps's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you invision the trangular shaped piece that the mirror is attached to, like a sail, pinch the top portion of the trangle. Remember the forces that initially distort this piece are from the window being man handled. Your objective is to reverse this action... sorry no picture yet.- I finally got it stuck
I love the scientificological approach. Go Nippy!- ah yes, tuneups
brus brother replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBreaking News: Nipper goes out on a limb with outrageous claims...- Oxygen Sensor Mayhem 98 Legacy
brus brother replied to burmzie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you using Suabru or aftermarket parts? This may explain some of the wirigging.- How to fix `01 OBW Front sunroof?
brus brother replied to bawalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Subaru parts department parts blow up will show all the scews, connectors and widgets. I doubt the manuals would be that specific.- How to fix `01 OBW Front sunroof?
brus brother replied to bawalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've used the following technique for various applications. Go to your local Subie dealer parts department and ask them to copy the parts page for your sunroof;). That should show you the innards and you'll probably be able to figure out what's what from there.- are expensive spark plugs worth it?
brus brother replied to 91LegLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI didn't mean to trash Autolite plugs. What Nipper accurately pointed out to me is that though the cooler NGK plug was accurately cross-referenced to an Autolite plug, the issue of temperature range was better addressed by staying within a manufacturer since it is in fact a "range". The pinging issue was much resolved when I went back to the NGK series and experimented within their ranges. With some trial and error, likely there is an Autolite plug that would suit my needs but for the moment, I was able to eliminate one possible variable by staying within one manufacturer.- are expensive spark plugs worth it?
brus brother replied to 91LegLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo do you add octane boost every tank??$? I am using 87 octane as spec for car. The cooler plug was a suggestion from the site and agreed upon by subaru tech who has tried every other trick in the book to remedy this pinging situation which existed from day 1 for the car. This included flashing the computer, new plugs, air and fuel filter, checked and replaced timing belts, changed knock and MAP sensor, head gasket and checked and removed any trace of carbon, cleaned throttle body and did upper engine cleaning with Subaru top engine cleaner and Seafoam.I've been using the new plug for less than a week but the pinging seems to be reduced. The problem is definitely related to ambient temp and humidity so I'll give it a little more time before posting the actual results.- 30,000 Maintenance
brus brother replied to Lone Ranger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, I'm all for staying within one's comfort range and knowing when to say when, but I've done my 2000 Legacy plugs a few times, making sure to use antisieze compound on the threads. The plugs may be bit tight to remove at 30K miles but subsequent changes with the antisieze compound make it a snap. Access may be a pain, but slowly remove the air intake on the right and window washer on the left (drain, unplug and unbolt). The first time will take a little deciphering but it is intuitive and you'll get it.Go slow, one at a time, grab the boot not the wire and give it a side to side and out pull. I have found that the OEM plugs are gapped properly and Subies seem to like the NGK spec plugs though recently I switched one step cooler experimenting with a pinging problem (another story). Carefully thread the new plug in by hand and don't force it. If it seems hard, stop and rotate counterclockwise and then rethread so as to not cross the threads. It's a feel thing. Use the search function on the site and there are instructions for changing fuel filter.- 30,000 Maintenance
brus brother replied to Lone Ranger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXList the items they want to do for $900. As I recall, a lot of the items on the check list besides plugs and oil are check this, inspect that, fill washer fluid, drain wallet... I would say that depending on your driving conditions, the brake fluid could be changed when you do your first brake pad change.- are expensive spark plugs worth it?
brus brother replied to 91LegLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOnce again, the Grand Poobah Nipper is spot on. I have been wrestling with pinging for many years and in an attempt to reduce it, I switched to a cooler plug. NGK wasn't available so I went with the cross referenced Autolite and wasted my money. The pinging was worse. As per Nippy's suggestion, I finally got the NGK cooler range plug and there seems to be some improvement but certainly better than the Autolite experiment.- There's an 06 WRX TR in my driveway...
brus brother replied to DerFahrer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReturn it ... and ask for a full refund.- 98 obw shudders on slow turns
brus brother replied to JGromada's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK Nipper, if you're so smart, can you spell Mississippi?- 98 obw shudders on slow turns
brus brother replied to JGromada's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the fuse verifies torque bind, from what I've read here, change the transmission fluid a few times yourself, just drain and fill, drive around for a few days, drain and fill again and maybe again but NO transmission flush and sometimes it clears up. I think theory has it that the flushes might loosen up stuff that is better left undisturbed.... I only know what I've read!- rings/whistle during acceleration
brus brother replied to vanbasten's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould your jinglings be engine pinging which sometimes sounds like chains rattling? This would occur under load.- Blu is back home - clutchpack.
brus brother replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy recent experience with SOA retail... brake pads for $90 YIKES! Are those extra shims made from titanium? At least there is some relief from online dealers but even the $65 on line price seems a tad high. In addition, considering Autozone's lifetime rotor warranty (read no more concern for warpage etc.), SOA seems userous there as well. Let the buyer beware.- rings/whistle during acceleration
brus brother replied to vanbasten's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDamned if I didn't do that myself... the subie got a little breathy till I figured it out...- clicker torque wrench... any good?
Well then, does it make a substantial Woofa Woofa Woofa Woofa sound when you hurl it across the room in disgust?- clicker torque wrench... any good?
Just saw Harbor Freight selling a 1/2" cicker torque wrench for $13.00. Has anyone used these and can comment on accuracy and durability? Would you trust it to torque a head with one of these?- Still no horn :(
brus brother replied to bhelser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood warning though. We don't want this fellow smooching with an airbag whilst trying to fix his horn.- Still no horn :(
brus brother replied to bhelser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Nipster may be correct: Replacing Subarus aging Loyale, the subcompact Impreza came in 4-door sedan and station wagon form, with standard front drive or optional permanently engaged all-wheel drive. Sales began in spring of 1993. Both body styles came in L or step-up LS trim, and seated five. A driver-side airbag was standard; antilock braking standard on the LS. Another site mentions that dual airbags came on the scene in 1994. - Low Brake Pedal - 2001 Forester L
