brus brother
    44
Everything posted by brus brother
  1. Are you using Suabru or aftermarket parts? This may explain some of the wirigging.
  2. The Subaru parts department parts blow up will show all the scews, connectors and widgets. I doubt the manuals would be that specific.
  3. I've used the following technique for various applications. Go to your local Subie dealer parts department and ask them to copy the parts page for your sunroof;). That should show you the innards and you'll probably be able to figure out what's what from there.
  4. I didn't mean to trash Autolite plugs. What Nipper accurately pointed out to me is that though the cooler NGK plug was accurately cross-referenced to an Autolite plug, the issue of temperature range was better addressed by staying within a manufacturer since it is in fact a "range". The pinging issue was much resolved when I went back to the NGK series and experimented within their ranges. With some trial and error, likely there is an Autolite plug that would suit my needs but for the moment, I was able to eliminate one possible variable by staying within one manufacturer.
  5. So do you add octane boost every tank??$? I am using 87 octane as spec for car. The cooler plug was a suggestion from the site and agreed upon by subaru tech who has tried every other trick in the book to remedy this pinging situation which existed from day 1 for the car. This included flashing the computer, new plugs, air and fuel filter, checked and replaced timing belts, changed knock and MAP sensor, head gasket and checked and removed any trace of carbon, cleaned throttle body and did upper engine cleaning with Subaru top engine cleaner and Seafoam.I've been using the new plug for less than a week but the pinging seems to be reduced. The problem is definitely related to ambient temp and humidity so I'll give it a little more time before posting the actual results.
  6. Well, I'm all for staying within one's comfort range and knowing when to say when, but I've done my 2000 Legacy plugs a few times, making sure to use antisieze compound on the threads. The plugs may be bit tight to remove at 30K miles but subsequent changes with the antisieze compound make it a snap. Access may be a pain, but slowly remove the air intake on the right and window washer on the left (drain, unplug and unbolt). The first time will take a little deciphering but it is intuitive and you'll get it.Go slow, one at a time, grab the boot not the wire and give it a side to side and out pull. I have found that the OEM plugs are gapped properly and Subies seem to like the NGK spec plugs though recently I switched one step cooler experimenting with a pinging problem (another story). Carefully thread the new plug in by hand and don't force it. If it seems hard, stop and rotate counterclockwise and then rethread so as to not cross the threads. It's a feel thing. Use the search function on the site and there are instructions for changing fuel filter.
  7. List the items they want to do for $900. As I recall, a lot of the items on the check list besides plugs and oil are check this, inspect that, fill washer fluid, drain wallet... I would say that depending on your driving conditions, the brake fluid could be changed when you do your first brake pad change.
  8. Once again, the Grand Poobah Nipper is spot on. I have been wrestling with pinging for many years and in an attempt to reduce it, I switched to a cooler plug. NGK wasn't available so I went with the cross referenced Autolite and wasted my money. The pinging was worse. As per Nippy's suggestion, I finally got the NGK cooler range plug and there seems to be some improvement but certainly better than the Autolite experiment.
  9. If the fuse verifies torque bind, from what I've read here, change the transmission fluid a few times yourself, just drain and fill, drive around for a few days, drain and fill again and maybe again but NO transmission flush and sometimes it clears up. I think theory has it that the flushes might loosen up stuff that is better left undisturbed.... I only know what I've read!
  10. Could your jinglings be engine pinging which sometimes sounds like chains rattling? This would occur under load.
  11. My recent experience with SOA retail... brake pads for $90 YIKES! Are those extra shims made from titanium? At least there is some relief from online dealers but even the $65 on line price seems a tad high. In addition, considering Autozone's lifetime rotor warranty (read no more concern for warpage etc.), SOA seems userous there as well. Let the buyer beware.
  12. Damned if I didn't do that myself... the subie got a little breathy till I figured it out...
  13. Well then, does it make a substantial Woofa Woofa Woofa Woofa sound when you hurl it across the room in disgust?
  14. Just saw Harbor Freight selling a 1/2" cicker torque wrench for $13.00. Has anyone used these and can comment on accuracy and durability? Would you trust it to torque a head with one of these?
  15. Good warning though. We don't want this fellow smooching with an airbag whilst trying to fix his horn.
  16. The Nipster may be correct: Replacing Subarus aging Loyale, the subcompact Impreza came in 4-door sedan and station wagon form, with standard front drive or optional permanently engaged all-wheel drive. Sales began in spring of 1993. Both body styles came in L or step-up LS trim, and seated five. A driver-side airbag was standard; antilock braking standard on the LS. Another site mentions that dual airbags came on the scene in 1994.
  17. I just replaced front rotors and brake pads using SOA genuine parts and following instructions from the board, thanks. :banana:The kit included grease with instructions of greasing between backplate of pad and rubberized shim. Also instructed to grease the surface of support that recieves clip as well as surface of clip which is to be attached to pad. The rear set includes similar parts but no grease or instructions as above. Should I get some brake anti-squeal grease from Autozone and apply same as above? Probably a dumb question but confidence lacking competence can be dangerous.
  18. There is some elementary knowledge of electrical current involved here and if you don't already understand it, now is the time. I am no expert so it would be appreciated if another board member can correct me if I'm wrong so that we don't change bhelser into "sparky". The horn operates on the electric current supplied to it from your 12 volt battery through a few switches and relays. The electic current needs a complete circuit from the battery to the horn and back from the horn to the battery in order for the electric circuit to be complete and functional. For background purposes only and not as credit towards a doctorate degree in electrophysics, be advised that the current flows from the negative (ground)(-) to positive (+). http://www.mste.uiuc.edu/murphy/HoleFlow/default.html OK, enuf learnin', let's get fixin'. First you need to determine whether in fact your horns are operative or have been rusted solid. You can supply current directly to the horn using a simple jumper cable. There should be a wire running to the horn. Disconnect this wire. Check to make sure the terminal on the horn is clear of rust etc. and check the inside of the wire connection also. I am a little fuzzy here but I believe the ground (negative) at the horn is achieved by the bolt attaching the horn to the car which makes its way back to the battery via the grounded wire attached to the negative (black) terminal on the battery. To be certain, you could establish a ground from the negative (black) terminal on the battery to the body of the horn by using a wire with alligator clips from the battery(-) and running to some bare metal (scrape the paint off) of the horn. Now you can connect a long wire with an alligator clip from the terminal on the horn and touch the other end to the positive (red) terminal on the battery, the horn should work. If it doesn't or only makes a faint chirping sound, the horn is rusted or crudded up on the inside. Report back and we'll try and figure out how to get you good and horny.
  19. How about heading RichieRich's advice and hotwire the horns directly from the battery and see if those tooters even work?
  20. http://www.subarupartsforyou.com/cp_partlistbymod.php?subcat=Fuel+Pipe&model=Legacy If you check out the above link, I'll think you'll find that Nipper's caveats might be spot on. There are numerous web discounted Subaru parts dealers out there. The above link happens to be near me in CT. As for the $150 price given you, even retail doesn't come close to that for your model year so that dealer might have been sticking up the old gas pipe for you. Your's discounted could run you $89-$99 plus s/h. But beware that apparently there are two different models for 1996 based on month of production and Vin. Then again you might be able to hammer anything home to your satisfaction. These pipes rust out beacuse the "protective" shroud traps dirt and road salt = hole.
  21. The salesmen I've asked seemed unimpressed with sales figures... I personally would have preferred had they expanded on the Outback 05 styling and functionality (kinda like a mini Lexus) and look forward to the B9 style sensibility driving away. (Admittedly, the grillwork seems balanced on smaller models likely the WRX). If only the world was completely responsive to my wishes...
