43
Everything posted by brus brother
Wind Noise
brus brother replied to excal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It is the triangular gusset that the side view mirrors are attached to. Subies have a frameless window door. Every time you close the door by pushing against the window or flex the window as when exiting the car in a tight driving spot and pressing against the window, it flexes that trangular area by the mirror. SOA replaced my gussets under an extended warranty but the tech also showed me that with the window down, try gently compressing (pinching together) the top of the triangle and thereby restore the original "seal" from wind noise. I'm not sure how well that technique works as I have been very careful about how I handle the glass since the gussets were replaced. -
mirror
brus brother replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Use a small screwdriver to gently pry off the speaker grill and you should then see the actual speaker being held on by the same nuts that hold the mirror to the outside. -
mirror
If there is a triangular shaped piece at the inside of the door from the mirror, gently pry it loose and you'll find a few nuts behind that should tighten it up. The triangular piece has three small plastic wings that can be broken if you just tear into it. -
The grommets were done on my 2000 under warranty at the time and they replaced the valve cover gaskets I guess because SOA allowed this as a billing procedure. You may get away with reusing the old valve cover gaskets if they aren't damaged in removing the valve covers. You have to replace the grommets from the inside of the valve cover. Get a price breakdown from Discount Parts (remember when you call Liberty Subaru, ask for Parts and when Parts answers, ask, is this Discount Parts, then ask again if the price they quote is the Discount Parts price). You basically get the same price a local mechanic/shop would get. You don't have to replace valve cover gaskets to replace spark plugs but you need to remove the valve covers to access the grommets. It seems like you may have limited grease experience so I don't want to encourage a sink or swim attitude. If you aren't comfortable removing the valve covers then let someone else do the grommet work. Once in there, after they do the grommets, they can install the new components of plugs and wires instead of putting the old ones back on as they put things back together. The work isn't that difficult and might be a good father/son experience... every son needs to learn how to curse sometime! As far as Subaru repair info, use the SEARCH function on this site. Other basic auto repair stuff is available all over the net. The members here are very helpful so don't get hurt and ask questions if you get stuck.
Liberty Subaru in your NJ has an online parts department. Call them up and ask for Discount Parts and buy genuine Subaru parts for cheap. The oil on the plug wires is a result of leaking grommets where the plugs go through the valve cover. Might as well replace them and the valve cover gaskets at the same time. Check with your dealer and see if this is considered part of the 5 year 60K drive train warranty. If it is, buy the wires and let the tech replace them when he does the grommets/gaskets:banana:. Yes you need to remove a few items to get to the plugs (washer unit may be able to be pushed aside but then again, if you change the plugs, you'll want clear and easy access so as to NOT cross thread those babies. You'll need a deep socket and extension to reach down in there and oh by the way grab the wires close to the plug. I know you're replacing them but it's good practice to see how to do it right.
Followed directions. Run AC on high. Attach hose/gauge with quick connect to L side. Read pressure (in low range). Disconnect from L port and attach can. Reattach quick connect and kept filling and checking and as per instructions kept can upright. Gauge read just over 25 (just into the OK zone)and when I disconnected coupling and detached can, a small amount of gas and oil remained and was discharged from the can. There was no instruction on purging the line though in hindsight I could have pulled the trigger and release the valve in the quick disconnect coupling thereby assuring gas in the line... next time. For now, it seems to be running cooler but then again Nipster, I'm just across the Sound here in CT. and it's pretty darn cool today. Just spoke with Interdynamics/manufacturer and was told there is no way/need to purge their 11 inches of hose... Space Shuttle Challenger (o-rings??) Go with throttle up...
OK, used the Walmart gauge/hose and screw on can (pretty straightforward) and it was low. Added almost 1 can to get it just into the low end of the full range and then it didn't want to take the remainder of the can. Do these cans normally empty completely or is there an equilibrium point where the pressure in the system is the same as the pressure in the can and it stops taking more oil/gas? It definitely seems to be cooling better and I managed not to sacrifice any animals in the process.
Did the Walmart charge help or is tepid the norm for those years? As for Wayne's caveats, I do prefer to avoid shrapnel injuries where possible so if someone can point me to the low pressure side, it would be appreciated. Also, is there a need to remove/evacuate the old oil or is this simply a process of topping off what refrigerant/oil has been dissipated or used up? It strikes me as odd that I never have to recharge my refrigerator...
Is there any rule of thumb as to how long the original factory AC charge is good for. My 2000 seems tepid under extreme heat and I was wondering if it is just "used up" and in need of recharge. Is there a way of measuring the refrigerant oil to determine its' "coldability"? Are the recharge meters/freon cans from Wal-mart as good as any other method?
