brus brother
    43
Everything posted by brus brother
  1. OK Set the multitester to Ohmmeter. You will need to have a probe connected to each lead and first touch each probe together. You will see the needle move which indicates that you have a completed circuit. Now if you touch one lead to one end of a wire and the other probe to the other end of a wire you should get the same result as above if the wire is a continuous circuit (continuity) and not broken. If you set the multitester to DC Volts and touch the red (positive) lead to positive battery terminal and the black (negative) to the negative battery terminal you will see 12 volts registered on the meter. Now move away from the battery to the switch and check that you've got power to switch and then each relay and leg of wire. This will indicate if the wire is conducting electricity from the last know point where you discovered current. Electricity is quite linear and the process is intuitive once you know the basics. Even if you don't solve this problem yourself, get friendly with multitester and follow the logic and process that finally fixes this for you. Hope this helps.
  2. Good question. What are the indications for doing all this work? Mechanic's child entering college next fall? Watch the fluid level very carefully. Test for hydrocarbons in fluid etc. If there are overheating problems and the mechanic actually filled and got the air out of your coolant system then consider the nasty deed.The price is insane. CCR Engines will ship one for about 1/3 what you've been quoted. CCR may even talk you into a 2.2 bulletproof engine instead of the plagued 2.5.
  3. Looks can be deceiving. Did you use an ohmmeter to test for continuity/resistance? This is the only predictable way to check for a break in the wire. Let us know if you are unsure of how to use a multitester.
  4. "airbags were not deployed. (Which was great because that's the most expensive part of a repair sometimes.)" True, true. Some insurance companies will total the car based on the cost of repairing/replacing sensors and bags. I didn't read about insurance or the like but hope you got your car road ready without too much pain. The fellow at least took responsibility and didn't claim that the boulder hit him. Take it from someone who has lost friends in auto accidents, thankfully only feelings and fenders were hurt.
  5. Did it on a 91. Screw at the door pull beneath square plug. Screw behind door lever, behind pop out plastic trim. Screw at front lower corner and then pop connectors the rest of the way around. The door rests on a channel near the top that you'll need to lift the panel above. Once you have the door panel released, you need to disconnect the harness to the auto locks and window controls.
  6. Well I tried the gas tank repair epoxy from Autozone $3.00 and it seems to work as advertised. It's a two part putty where you knead the two parts together and just press it onto the area to be repaired which should aready be sanded and cleaned using a brake degreaser or other cleanser (check package).
  7. Well, I went back and didn't see that you had actually tried to swap in a different relay?? I was trying to prevent more trouble with my suggestion. Oh, by the way, have you tested the fuse or changed any bulbs? Seriously, there have been some fairly exhaustive scenarios presented and questions posed. I would suggest you slow that buggy down, start again and 1. Check owners manual for normal expected operation of your Veehickle. 2. Change the damn fuses or at least remove them and test them in your hand 3. Start at the battery and jump power to the light 4. Once you know the bulbs work (I'm sure they do as they are all brandy new) remove the fuse and gradually work backward from the light with a jumper from the battery at each junction until you lose power to the bulb. Remember that you can keep cutting that same board and it will still be too short.I don't mean to be a wise rump roast, just speaking from my own history of persistent yet stubborn failure. Good luck.
  8. I've been following this post and will be nostalgic when it's gone! Anyway, is it possible to test the relay any other way than as described in this post? If there is a short, might it not cook this other "swapped in" relay as well? Now you'd need 2 relays and have to still find the root cause of the problem!
  9. How bad is the leak?? I am about to embark on a ?repair of the inlet pipe. It rusted out at the usual spot, right at the bottom of the bend where sand and salt cake up inside the "protective" cover. I found an epoxy kit at Advanced Auto and Also at Autozone that requires LIGHT (KABOOM) sanding, pretreatment with alcohol (the metal not the operator) and application of epoxy and mesh. It's less than $10 and I figure it's worth a try since those darn phillips screws holding the filler tube in are as tight as... well they're real tight. It's a '91 and has seem many a Northeast winter.
  10. The heat shields surround various parts of the exhaust from the y pipe back. Slide under the car and bang on the various components of the exhaust. Use the Search function on this site where you can find different solutions from using a sheet metal screw to tighten, stuffing steel wool between the shield and the exhaust or depending on how much of a risk taker you are, cut it off if it is really loose and stay out of high grass. Of course, stock replacement of the section is always an option.
  11. Do you know the original owner? Is this info available through Carfax or the dealer who may have sold you the car? Perhaps this trail of bread crumbs will help identify the original dealer, installer or manufacturer of the alarm. Who knows, you might even make it operable.
  12. Search around here and there are some (me included) who aren't thrilled with the handling of the 05 OB. There are other Legacy/OB sites where some immediately considering upgrading suspension and tires. While I'm not quite as fanatical, it's a bit sloppy in hanling even compared to the tuned suspension of my 00 Legacy GT (both wagons). I didn't drive the new GT Legacy so I can't say anything about its suspension. I was trying to avoid the high octane requirement of the turbos. The ipod is an issue on the 05s. Use the Search function on this site. The early stock face plate for the radio/HVAC is one piece (now 2) making aftermarket changes difficult and there is not a clean ipod interface. It's a 1st year production issue that should be rectified by 06. 06 models should be here in August but rebate/incentive deals don't usually appear for at least a few months after that. By then, the 05s you're looking at now will be heavily reduced for clearance. BTW, used to go swimming in the abandoned quarry up Lochearn (sp.) Rd. in the late 70s and tubing on a river in the same area while attending UMBC Baltimore when Fells Point was just a bunch of funky dive bars... and now?!
  13. OK for the out of towners, Tribeca was a term coined by clever real estate agents to sell what was at the time a dreary part of Manhattan, formerly industrial and commercial loft spaces. TriBeCa stands for the Triangle Below Canal street. As it turned out, the marketting worked. This area, blocks away from the former (I hate saying that) World Trade Towers became one of the more trendy NY neighborhoods. The car is still UGLY!
  14. The one that has been driving me mad appears to be styrofoam agains styrofoam lining the insert of the trunk compartment on my Legacy 00 wagon. I tried silicone spray but it didn't help. Is there a magic fix?
  15. For giggles, while at the dealer today I got the service dept. to scan the interior trim panel parts blowup for me. Appears there may be a screw inside the light at the rear lower corner but this may be just to attach the light. If you need the schematic, PM me and I might be able to fax or scan and email attachment. I don't know how to do it on this site.
  16. For giggles, while at the dealer today I got the service dept. to scan the interior trim panel parts blowup for me. Appears there may be a screw inside the light at the rear lower corner. If you need the schematic, PM me and I might be able to fax or scan and email attachment. I don't know how to do it on this site.
  17. The 2.2 is a brilliant idea. They are reputed to be bulletproof. A local one would seem a reasonable solution considering the mileage on your vehicle. When I was investigating replacement engines for my cousin, Emily at CCR did mention that they had the 2.2 if you can't find one locally.
  18. I've spoken with Emily and she is very generous with her time and information. With a used engine, you still have the issue of head gasket failure. While this may not have been the cause of your engine failure, it is common with this vintage. A rebuild from Emily has the improved HGs and a 3 year 30,000 mile warranty. No, I don't work for CCR engines but the logic is sound. It all depends on what you want to do with the car. If right now it is only uiseful as a planter then it's either part out the car or invest the ?$3K for the rebuild/install, less if you do the install. If the rest of the car is still good to go, ask yourself where would you replace it for the same money and get a warranty to boot. Say hi to Emily for me... one more referral and I get a free air freshener for my car! BTW, was your engine's demise the dreaded head gasket failure? Good luck
  19. There's a posting on this same page of someone trying to install speakers on an 05 OB and he says the bottom is the usual pop clips. This might be all you need. Currently he is at a loss with how to get beyond the lower section. Slip a flat screwdriver or small thin prying tool behind the edge and pry out. Then slide along till you feel the next one etc.
  20. There's a fellow searching this same info right now since his kid slid his credit card down the window slot. He may luck out in knowing the bottom pops out. I did look for the screws in the arm rest etc and couldn't find any of the usual ones. The older models in addition to the screws needed to be lifted in an upwards direction off of a channel. As far as the faceplate, there is a replacement two piece unit being used by Subaru now and available as a replacement part. Apparently, the boys in design were a little slow on the pickup in this regard... doh. The issue is actually discussed on the NHTSA site under Technical Service Bulletins (TSB) for the make and model.
