Everything posted by brus brother
Help! Removing Icthus (Fish Symbol) from my car?
brus brother replied to NorthWolf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you really tried hard enough?
windows squeeking and making odd noises
brus brother replied to blatant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there any difference if the door is open or closed i.e. is it a rubbing on the weatherstripping kind of noise or mechanical squeal from the mechanism itself. If it's the former, clean the weatherstripping and maybe try some silicone spray on the rubber. I'll defer to some greater minds on the silicone issue.
brus brother replied to NorthWolf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDirections please?
brus brother replied to NorthWolf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpeaking of "Relativity", looking around at some of my relatives, I can see the phylogeny and behavioral similarities to the apes. If on the other hand, you choose the path of divine inspiration and you examine the collective mankind, you gotta wonder that at times, God was likely an underachiever. BTW, my original comments were gleaned from Borowitzreport.com and a satirical look at the Kansas school system removing Darwin and company from the texts. Addendum: Unfortunately unlike those with FWD, for the AWD owner, when we reach the end of the earth, the rear wheels will propel us over the edge and into the abyss. See ya there!
brus brother replied to NorthWolf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMT, don't jump to conclusions. Proposed curriculum changes from would have us believe that whole Darwin thing, probably as well as the entire 20th Century is just a theory.
Hi Everyone, Just came by from NASIOC
brus brother replied to eddiec168's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome. Please wipe your feet before entering. Thank you.
rubber floor mats and armrest extension
brus brother replied to rizzo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVelcro strips?
brus brother replied to rizzo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour assumption is probably right about them just tossing you whatever was around and yeah you should search for a replacement for the driver's side or rig the one you have (punch a hole where the post would line up). Try going back to the salesman and tell him you nearly killed a pedestrian when the mat got tangled around your brake pedal! If he is unresponsive, run him over and render him even more unresponsive. There are a number of Subaru dealer/discount parts suppliers. 1stSubaruParts.com (west coast) and Liberty Subaru in NJ have their discount parts department. It's the same as their regular parts supplier but they discount if you assk for it! Dan Perkins Subaru in Milford CT. will also give an online price. Pay shipping/no tax.
B9 Tribeca hits the showroom floor! (photos)
brus brother replied to Subie Gal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere can I get an Edsel?
Rusted through
I just realized that the gas filler tube on my 91 Legacy has a "protective" shroud that trapped years of road sand/dirt/salt and caused the pipe itself to rust through. Check yours out just behind the passenger rear tire. I also noted on my 90 Loyale and 00 Legacy that the same sand/dirt/salt collection occurs within the front quarter panel and you can access the area by opening the door and then rinse it out. Any other areas to watch out for?? An ounce of prevention....
Steering Tracking to Right
brus brother replied to Prauch007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX36psi seems high. What is recommended in the manual for your veehickle or on the door post on the driver's side? Fill 'em all to spec. and then run it on the highway to see if you still have a drifting problem. If OK, relax and wait to see if the tire runs low again and then get it fixed. I once had 4 new tires mounted and balanced and an alignment only to discover when I had drifting problems soon thereafter that they just eyeballed the tire pressure. Way to go boys, lunch time!
No running (tail) lights
brus brother replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK Set the multitester to Ohmmeter. You will need to have a probe connected to each lead and first touch each probe together. You will see the needle move which indicates that you have a completed circuit. Now if you touch one lead to one end of a wire and the other probe to the other end of a wire you should get the same result as above if the wire is a continuous circuit (continuity) and not broken. If you set the multitester to DC Volts and touch the red (positive) lead to positive battery terminal and the black (negative) to the negative battery terminal you will see 12 volts registered on the meter. Now move away from the battery to the switch and check that you've got power to switch and then each relay and leg of wire. This will indicate if the wire is conducting electricity from the last know point where you discovered current. Electricity is quite linear and the process is intuitive once you know the basics. Even if you don't solve this problem yourself, get friendly with multitester and follow the logic and process that finally fixes this for you. Hope this helps.
help! - need a new engine?
Good question. What are the indications for doing all this work? Mechanic's child entering college next fall? Watch the fluid level very carefully. Test for hydrocarbons in fluid etc. If there are overheating problems and the mechanic actually filled and got the air out of your coolant system then consider the nasty deed.The price is insane. CCR Engines will ship one for about 1/3 what you've been quoted. CCR may even talk you into a 2.2 bulletproof engine instead of the plagued 2.5.
brus brother replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks can be deceiving. Did you use an ohmmeter to test for continuity/resistance? This is the only predictable way to check for a break in the wire. Let us know if you are unsure of how to use a multitester.
Subaru Vs. Bolder
brus brother replied to hush777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"airbags were not deployed. (Which was great because that's the most expensive part of a repair sometimes.)" True, true. Some insurance companies will total the car based on the cost of repairing/replacing sensors and bags. I didn't read about insurance or the like but hope you got your car road ready without too much pain. The fellow at least took responsibility and didn't claim that the boulder hit him. Take it from someone who has lost friends in auto accidents, thankfully only feelings and fenders were hurt.
FM radio reception
brus brother replied to 93legacyman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChecked your antenna connection?
Opening door panels
brus brother replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid it on a 91. Screw at the door pull beneath square plug. Screw behind door lever, behind pop out plastic trim. Screw at front lower corner and then pop connectors the rest of the way around. The door rests on a channel near the top that you'll need to lift the panel above. Once you have the door panel released, you need to disconnect the harness to the auto locks and window controls.
Gas Tank Swap
brus brother replied to eman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell I tried the gas tank repair epoxy from Autozone $3.00 and it seems to work as advertised. It's a two part putty where you knead the two parts together and just press it onto the area to be repaired which should aready be sanded and cleaned using a brake degreaser or other cleanser (check package).
brus brother replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdemonic possession? good luck. please post back with solution.
brus brother replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell, I went back and didn't see that you had actually tried to swap in a different relay?? I was trying to prevent more trouble with my suggestion. Oh, by the way, have you tested the fuse or changed any bulbs? Seriously, there have been some fairly exhaustive scenarios presented and questions posed. I would suggest you slow that buggy down, start again and 1. Check owners manual for normal expected operation of your Veehickle. 2. Change the damn fuses or at least remove them and test them in your hand 3. Start at the battery and jump power to the light 4. Once you know the bulbs work (I'm sure they do as they are all brandy new) remove the fuse and gradually work backward from the light with a jumper from the battery at each junction until you lose power to the bulb. Remember that you can keep cutting that same board and it will still be too short.I don't mean to be a wise rump roast, just speaking from my own history of persistent yet stubborn failure. Good luck.
brus brother replied to Reason01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've been following this post and will be nostalgic when it's gone! Anyway, is it possible to test the relay any other way than as described in this post? If there is a short, might it not cook this other "swapped in" relay as well? Now you'd need 2 relays and have to still find the root cause of the problem!
Gas Tank Swap
brus brother replied to eman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow bad is the leak?? I am about to embark on a ?repair of the inlet pipe. It rusted out at the usual spot, right at the bottom of the bend where sand and salt cake up inside the "protective" cover. I found an epoxy kit at Advanced Auto and Also at Autozone that requires LIGHT (KABOOM) sanding, pretreatment with alcohol (the metal not the operator) and application of epoxy and mesh. It's less than $10 and I figure it's worth a try since those darn phillips screws holding the filler tube in are as tight as... well they're real tight. It's a '91 and has seem many a Northeast winter.
vibrating and rattling nosie when i downshift
The heat shields surround various parts of the exhaust from the y pipe back. Slide under the car and bang on the various components of the exhaust. Use the Search function on this site where you can find different solutions from using a sheet metal screw to tighten, stuffing steel wool between the shield and the exhaust or depending on how much of a risk taker you are, cut it off if it is really loose and stay out of high grass. Of course, stock replacement of the section is always an option.
Tires & Xmission Damage..Myth or Fact
brus brother replied to tomrose's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd now you have to catch up with that other tire!
Heat shield on muffler or is it not that kind of noise?
