43
Everything posted by brus brother
The apparent "fix" is to pinch the top of the triangle of the gusset while the window is down. The apparent cause of the problem is that since the window is without a frame on the door, when opening or closing the door, grabbing or pushing the glass is the culprit. It is a rather long lever arm that you create and you supposedly can twist the gusset sufficiently to cause the distortion. Also, if you find yourself in a tight parking situation and have to squeeze your body past the door, the effect is the same in distorting the gusset.
Hello
brus brother replied to 7thSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Well the title "new user" under your member name seems like a misnomer. -
And the answer is....Today, after 51/2 years of complaining, a clever tech pulled the covers off and checked the cam timing. It was off by one tooth. The pinging is much reduced but not completely gone. I had them change the timing belt early at 72K since they were in there and it only cost me $40 for the belt. Dealer suggests injector cleaning. Is there a DIY version or is the $129 dealer service worth the bucks? I have used BG44K every 30K but will this clean the injectors as well as the other service?
They changed the knock sensor today... no change. I showed the tech Blitz's IAT sensor option and while it is a different variety, it apparently chacked out. As far as my grammer, she and my grampa have been out of warranty for many years. Tomorrow they'll pull off the timing covers and check the cam timing.
My 90 Loyale had the usual rust as a result of dirt and debris collecting in the space behind the front fender that you can see when the door is open. I first detected the problem area through a rust hole from the outside. I have since had occasion to check the same area on my 2000 Legacy GT and sure enough, tons of road sand, mixed with salt here in NE. I flushed the area out with a garden hose while the nose of the car was pointed uphill. If the AWD ever fails, I know where I can get some sand for emergency traction. Another great idea from SOA.
http://www.ultimatesubaru.org/forum/showthread.php?t=1138&highlight=Ccr+engine CCR Engines Inc. has a good rep on this site for the dollar range you mentioned and you get a totally rebuilt engine for probably less than what you were quoted. You get a 36K/3 year warranty on the engine top to bottom. The above link has opinions on merit of rebuild or HG alone.
On my 90 Loyale, aside from the usual front end seal leaks, there were leaks from the valve cover gaskets and the little rubber grommets where the bolts atach the valve covers to the engines. It seems Subarus use leaking oil as somewhat crude anti-rust program. You can also earn some spare cash resealing asphalt driveways with your leaking car.
SEARCH function is is the gray bar at the top of this site, next to "new posts" and "quick links". Click on Search and a window will open below. Put in your key word and it will display results. My understanding of the oil leak is that it is a rear engine seal and is unrelated to the front of the engine where timing belts would be replaced. Good luck
I think I made it clear that the car has behaved this way from day one, so the various treatments meant to eliminate carbon etc. wouldn't have come to play with a brand new engine. The car has new plugs and the recommended gas line additive/cleaner BG44K. It behaves well when it is very cold outside. It is noticeably worse with warmer weather and high humidity(low air pressure?). Tech feels it is something mechanical. All guesses accepted and I will report back with any findings. PS I had originally been running 91 octane but ran into other owners who had no problem with 87 octane and since I'm still under warranty, I figured that I'd let them try and figure why the runt of the litter is in my driveway.
From day one, my 2000GT pings with the approved 87 octane. It does this under mild acceleration. The tech tried hard acceleration without pinging. Now they want to pull the covers and check timing. The latest computer flash has been applied without any remedy. It doesn't seem to misbehave when very cold outside but with warming here in the northeast, it is coming back. It's still under warranty. Plugs and filter are new. Any ideas?
My 2000 has started to develop a variety of squeaks from under the dash and around the rear gate. It might be from a bushing holding something beneath the car?? I can't seem to get to the one under the dash but I think the rear gate might do with some lubricant on the rubber gasket. Any suggestions for a lubricant? Does silicone adversely affect the rubber gaskets and bushings over time?
I am told that for my 2000 and 2005, the AT filters are lifetime filters. I suppose they are not counting on the Old Gen guys carrying on with the newer models as in the past (some still driving 1978 models?) or more likely know that the cars would never last as long... it's the car's lifetime not the driver's.
I had a similar problem. I wonder if there is an auto glass industry reporting that could evaluate the incidence of Subaru replacement experiences. If you could determine the number of replacement pieces either SOA or aftermarket that were being installed yearly and compare it to other auto makers, you might find a pattern worth discussing other than "yup, me two". In the meanwhile, as I stated initially, "yup, me too."
So there's the rub. If you have a shop do it and a leak follows, you can take it back to them and make them fix it. But do you have the time to chase them down. At 138,000 miles I changed the fluid on my 90 Loyale by the drain plug method. I bought the car used at 68,000 miles and couldn't say if it had ever been done by the previous owner. As I recall, there was a crush washer as with the oil plug. Pretty simple job.
Linda, Glad to see you're still in the game. If you click on Quailman's name in his post, you will have the option of sending him a Private Message (PM) or an e-mail. Sometimes we don't all stop by here regularly and you'll be able to more quickly determine if his notion of East of Pittsburgh is Belgium. Good luck.
