Starlite
Everything posted by Starlite
I have a 1989 superstation and going to buy a 1987 l18 superstation sparepart subaru. Will parts from 87 fit my 89 subaru?
Hello my windshield is leaking on the upperside on driver side. Its a subaru leone superstation 1989. Is my windshield glued or not? Thinking of using some kind of compound to seal the leak.
Hello i having problems with my radio in my Legacy 3.0 2007. Today before i was checking the cable couplings on the radio it worked but sometimes went dead for a while and sudden it started again. The fan control unit works well but radio screen was black. Today i checked the cable coupling and started the car and radio was dead and wont start anymore. It started for a couple of seconds but went dead again. Is there anyone else having the same problem?
Had the car to a local car workshop and had the coolant system tested for leak. If there was a leak the test gauge should get yellow. He only saw a tiny minimal amount of yellow on the tester. He was not sure if there was a headgasket or krack in the head. What else could be leaking? I have tried to watch from wich side of the exhaust pipe it smokes from and it comes from both of them.
I had a leak on my older subaru from 1989, This was a major leak on the head gasket. Bubbles ang smoke visible in the overflow bin. And sparkplug was wet. This problem is not that obvious. i dont smell like coolant but once i did a kickdown in front of a friend and she told me it smell discusting, and not sweet like coolant.
Hello i have some coolant problem on my legacy 3.0. When I drive and do a kickdown I will see a big white cloud behind my car. Driving normal and there's no smoke. Today a noticed the coolant expansion was empty. There is no water in the oil or oil in the coolant. So night it be a bad headgasket or something else? Is this a common problem on the h6?
Hello i have a Subaru leone superstation 1989 (Stationwagon) and got the offer to buy a 1986 2-doors cope with the same engine (Ea82 mpfi) but will the rest of the parts fit my superstation?
Subaru superstation 89 problems
Starlite replied to Starlite's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I see, then there is something wrong with the automatic, and i dont even know where to begin. The thing is that when warm the engine never goes down under 1000 rpm, -
Well the engine runs but have a very high idle when cold, eaven on summer. Where can i find the choke on my engine? i belive there must be something wrong whit it. -
Probably a cracked head. Or the head is bend. Or bad us made headgasket Going to make a leak down test and see what it says. -
No codes Today I noticed a old problem The engine have start to spitt water from the exhaust system again And the coolant box was almost empty Wt hell I have installed new gaskets and all was fine until now -
Anyone who know? -
Rpm is constantly on 1000. When i start it goes up to 2000 for a while. It takes 1.1 liters on 10km = 21.38 miles per gallon Is this normal consumption? sometimes the rpm goes down to 500 and the engines runs uneven, and seconds after it goues up to 1000 rpm. When i trying to drive slow on first gear it will stumble and twitch, Have changed cooling sensor (Not genuine part) Sparkplugs NGK Ignitioncables (Not genuine part) Rotor and dissy. (Not genuine part) oxygen sensor. (Not genuine part) Bosch. -
Timing checked. -
Well the engine is running but I have to high idle and sometimes it's hard to start the engine. I believe the coolant temp sensor is bad. I have tried with a new one, not original. Where can I get an original temp sensor? The Subaru in Sweden can't help me they don't even found the sensor in their lists. One more thing can I adjust the idle? -
Well you guys don't seem to understand what I trying explain so I will take a picture later this day You all talking about belt timing when I talking to set the distributor right in place. -
I want to know how to set the camshaft and the distributor. -
Find out it was a blown headgasket I have removed the camshaft on the distributor side and wondering if it makes any different how I put the camshaft back? Or is there any markings on the sprockets , camshaft and distributor?
