Location
Vancouver, WA
Referral
google "Subaru Loyale tune-up"
Biography
I'm a guy who has had some interesting cars, I've worked on my own for years now, I've got teenage sons who need to learn how to drive standard and do their own maintenance, and I just bought my first Subaru.
Vehicles
1992 Loyale wagon
mstr_pete's Achievements
Advanced Member (3/11)
3
Grrr...very frustrated. The wagon was running just fine. I was headed for the coast to do some camping and beach clean-up. I stopped for a cup of coffee, and *click*- nothing else. Jump-start did nothing. I cajoled a good citizen into helping me push-start it (LOVE me some stick-shift!), and i was on my way. I got back home on less gas than I expected to use, and lo-and-behold the starter has a lifetime warranty. Out with the old one, in with the new one, and...*click*. Sonofa----- Now what? I should have time to go at it again on Saturday, so what's the game plan? Again, it was running fine, and it starts right up if I roll it and pop a gear.
'92 Loyale 4x4: RWD, no FWD?
mstr_pete replied to mstr_pete's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It looks like the driver's side CV shaft has broken up at the output shaft. With the front wheels off the ground, engine running, and the transmission in neutral: the output shaft turns, there are grinding sounds, and the wheel doesn't turn. Same scenario, transmission in gear: output shaft turns faster, noises are louder. I expect that the mechanic who installed them will take care of this for me. CV axles ought to last more than 3,000 miles. I have video and photos but I'm not sure how to post them.- 8 replies
- loyale
- transmission
(and 2 more)
Tagged with:
I'll know more in the morning after I lift the front end.- 8 replies
- loyale
- transmission
(and 2 more)
Tagged with:
would it go all of a sudden like that though?- 8 replies
- loyale
- transmission
(and 2 more)
Tagged with:
Hmmm...interesting. I had a shop do the axles, but I will check the free turn.- 8 replies
- loyale
- transmission
(and 2 more)
Tagged with:
Hi folks, It's been a while since I posted here, 'cause the wagon has been running fine, but a BAD THING happened today. I was toodling home through my neighborhood when, upon starting up from a stop at an intersection, I heard a CLUNK and lost motive power. the engine was running and revving, and the car was...just...rolling. I hit the 4WD button on the shifter (this is a 5-speed) and the rear drive engaged. I got back underway, nice and easy, for the mile or so home. Once home, I took a quick look underneath the front end to confirm that the new CV axles and joints were still in place, which they were. So, I suspect a problem with or in the transaxle. QUESTIONS: Does that sound about right? Am I overlooking anything? What's the diagnostic procedure, or did I just experience it? Is this a repair, or a replacement? How big of a PITA is the job? Considering this car has 245k miles on it and needs new front engine seals at the next timing belt change (i.e. soon), is it worth pursuing? TIA
- 8 replies
- loyale
- transmission
(and 2 more)
Tagged with:
Unusual Temp Fixes To Get You Home
mstr_pete replied to roadsubiedog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've done a few over the years but this is the one I remember best: '85 Dodge 250 van, 318 engine, coming back with the family from California, radiator blew out. Long story, replaced it in a hotel parking lot, we're back on the road, but it's still running hot. We're in Blythe, it's a million degrees, I pull off the freeway and pop the hood. The upper hose from the heater control box is HOT HOT HOT and I figure I've got an air pocket. Trouble is, all the vacuum tubes from the heater control box are falling off, who knows where they go, I've got the wife and three toddlers, so I've got to figure this out. Engine off, fan on high defrost, I pull the hose and BAM a shot of hot air blows past my face. Found the air pocket, all right. But I've got to bypass the bad control box. What do I have? A mini-mag lite. I knock the guts out with a screwdriver and it's a perfect fit. Two hose clamps and a gallon of antifreeze later, the van is in permanent defrost mode and we make it to New Mexico. I ran it like that for a year, then sold it to a couple whose van blew up and needed to keep going to (old) Mexico. Good times. -
I've found that 1800-2200 rpm is the ideal zone for gear changes. Unless I use the clutch, that is ;-) Then I can go a lot higher.
Loyale Parking Brake Adjustment o_O
I will do that -
My '92 Loyale 4WD 5-speed has essentially no parking brake function, it is that far out of adjustment. It holds okay on the level, but any incline will defeat it. The trouble I'm having is that the setup on the vehicle looks nothing like the diagram in the Chilton book, so I really don't know where to go with this. I haven't found anything on this topic in this forum either. I know that the parking brake works on the front wheels, but what I see is heavily shielded cable running from somewhere amidships to the back of the caliper, with nary an adjustable point in sight. What am I missing?
