About Anonymous907
- Birthday 12/20/1992
Gender
Male
Location
Anchorage, AK
Interests
Off Roading
Occupation
EMT-I
Referral
Searched for off-road subaru parts
Biography
AK born and raised.
1990 Subaru Loyale Wagon
Stacked
Snorkeled
2" lift
29" BFG KM2's
EA82
Auto (looking to get a manual with dual range)
Chop top
Lights every where -
Vehicles
Anonymous907's Achievements
Advanced Member (3/11)
I have been on the interwebs and all over this forum for the last few days and can not seem to find anything on performance alternators (100+ amp). I've been building up a lifted Subaru for some time now and have recently put on a but load of lights. My stock 60amp does ok when not running all the lights at once, but I just purchased 2 12" led light bars for it and I will definitely need to upgrade now. Does anyone on here know where I can pick up a 100-160amp alternator online? I drive a 1990 Subaru Loyale with the EA82 automatic in it.
1990 Loyale: some sort of electrical short
Anonymous907 replied to jasonkaye's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just tried the jumper cables instead of the regular battery cables; still nothing. :/- 15 replies
- loyale
- electrical
(and 1 more)
Tagged with:
So I'm having the same problem in my 1990 loyale. Kind of. No power to anything. Not a singal light or dash. No buzzing or humming etc. Picked up a small semi horn to install, drove home, unhooked battery and then the horns, or what I believed to be the horns from behind the front bumper, plugged my battery back in to make sure I actually removed the horns, and nothing for power. I did the stretch test and none of the fusible links (grn, red, grn, & blk) appeared to stretch. I replaced my ignition switch and still nothing. Cleaned all my connections on the battery, the connecting terminals, where they connect to the block, and even pulled the battery out of my DD truck to hook in hopes it was just a bad battery and, after all that, I'm still getting no power to anything. I did plug back in what I believed to be the horns and still nothing. All the fuses inside the cab are good as well. Double checked every last one. Tested my alternator and I'm still getting good power to that. I'm at a loss and really can't afford a shop. Any other ideas?- 15 replies
- loyale
- electrical
(and 1 more)
Tagged with:
Ea81 electrical power loss
Anonymous907 replied to 82GLWag's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I guess I'll have to take a look. Thank you.- 5 replies
- Ea81
- Electrical
- (and 6 more)
I'm having the same problem in my 1990 Subaru Loyale Wagon 4wd with the EA82 engine. I know what you're talking about, but where would be a good website to find these fusible links? I know google or the local shop, but maybe you have a recommended site? I like to do things myself. As for checking the underside of the block, where exactly? Or are you just talking about checking for any loose grounds, etc? Where is the ignition switch? Sorry for all the questions haha Don't mind the newbie over here- 5 replies
- Ea81
- Electrical
- (and 6 more)
My 91 Loyale Wagon Project
Anonymous907 replied to Anonymous907's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Got plans for steel tube bumpers front and back w/shackles and a winch up front, external roll cage, external/removable fuel tank in the trunk for long trips, I still want to run all independent suspension, but I am in the market for a 4" suspension lift kit & 1" body lift. Also I have heard that I will need to extend my steering column and adjust the camber to do this much lift. Anyone have an idea on where I can get one or what year, make, and model of subaru I can pull one off of? Or any advice when doing the lift? I really don't want to run these old struts either. Anyone know a good relatively inexpensive alternative? Preferably a coil over deal.- 4 replies
- 1991
- subaru loyale
(and 6 more)
Tagged with:
I also painted the bar that is going across the top which is my soon to be light bar or so I thought. Just recently decided to go ahead and just build a custom roof rack / spare tire carrier / light bar to the top. Hopefully have that up in the next week or 2. Got a friend willing to weld me one together for a case of beer Just need the money for supplies. At the time of the snorkel being painted I decided to paint the original steel rims as well. Before: Primered: Painted Gloss Black: I plan to do a 6lug conversion eventually, but couldn't resist this step on the wheels that are on there now. Yesterday was the last time I worked on it. Decided to go ahead and start a full paint job all the way around. Kind of scratching for cash at the moment so I only got the hood done and another quarter panel in the rear prepped for bondo. I did a Matte Black paint job. This is only temporary though. It will soon end up hand painted by myself and friends as I am bringing it out to a music festival in July to let people paint my car. After that it will be clear coated and done Looks pretty good so far I'd say. After First coat Finished Product Stay tuned and any ideas are greatly appreciated! I will be posting all updates here- 4 replies
- 1
- 1991
- subaru loyale
(and 6 more)
Tagged with:
As you can see in the pic, there's a big chunk missing out of the rear fender... That's cause I cut it out. It was nothing but rust. SO, I will be spot welding some chicken wire on this section for bondo to adhere to so it will fill in this gaping eye sore. That will be later in the build as I still have other things to attend to. Since I brought it into town a month ago, she still runs great, but is now leaking oil ever so slightly since I cleaned the outside and the engine... I will give this attention later as it's just a real slow drip right now. Now, that air filter problem... Well, it's no problem anymore. Capped with a Spectre air filter. To do this I cut the mounting part off of the stock MAF Sensor to make it perfectly round so I could clamp on my aluminum dryer hose in prep for the snorkel. Then about 2 days ago I decided to paint it- 4 replies
- 1991
- subaru loyale
(and 6 more)
Tagged with:
Well, I loaded it up on the trailer after all that to bring it into town to have the wheel bearing removed and replaced so it could be mobile again since I couldn't get it off for the life of me. The shop even had to do it twice as they broke the first bearing they ordered. lol- 4 replies
- 1991
- subaru loyale
(and 6 more)
Tagged with:
Hello, I am new to this sight and have recently started my first project car; a 1991 Subaru Loyale Wagon 4wd and this is my build thread So here's the story behind the "Shaggin Wagon" My room mate bought this car in early 2013 as a commuter for $900. It had it's quirks, but she ran soild at a 175,000 miles with the famous subaru tick of course lol Friend decided to take it out to a popular off-roading place called Jim Creek here in AK. Sure enough, he ran it into the ground. Blown out wheel bearing, blown out ball joints, cracked fuel line, blew apart the timing belt trying to drive it home, water pump was done, and clogged the air filter trying to cross a river which is what I think caused the belt to snap later on. As it sat at my other buddy's place for about a year I decided it would be the perfect car for my first real build. Drove out there about a month ago and bought it off of him for $200 as is. Before I towed it into Anchorage to begin the build I couldn't help but start to work on it where she sat. Before I did anything I changed out all the fluids. New tranny fluid, oil change & filter change, new fuel line exiting the filter and fuel filter, new spark plugs, wires, and distributor cap, and power steering fluid change. Next step; I picked up a new timing belt and re-timed the engine. Also replaced the water pump at this time. Messed up the seals a bit on the timing belt cover, but I am about to order a new seal in about a week from this upcoming Friday. I just needed to make sure it still ran and sure enough, she fired right up. Next thing I decided to tackle was shedding the wagons weight a bit First, the hatch needed to come off. Next up, roof removal lol In which case we got a little over zealous and shot it... Nothing a little bondo can't fix though. The day after the trunk removal I decided a little bit of spray on bed liner to the floor boards wouldn't hurt. I only have pics of the paint job thus far, but I may take more later on for sake of the thread. It's hanging in well though Had one more thing to do before I could bring it in to town. Decided to cut the fenders. Ugly job, but it'll do the trick. My goal isn't to make this thing pretty. It's to make it get me where I want to go. May even do more cutting as I will be running 28's here in the future. Flares are on my list as well, but that'll come later on once I actually get the tires.
- 4 replies
- 1991
- subaru loyale
(and 6 more)
Tagged with:
