Jon H.
Everything posted by Jon H.
  1. Which year outback sensors will work? I've already ordered the PC203 but if it's cheaper then $160, if I have to replace it again I'll do that. What about the cam angle sensor PC180, is there a cheaper alternative then $160. Also, in case mine is pooched, would I be able to use an F9 ecu from a 1992 or 1995 legacy? It looks like the connectors are the same. I've read that there might be some differences with the injectors. But I could swap them too. There is a lot more of these at the scrap yard then SVXs! Thanks for the replies Jon
  2. I just installed 1992 SVX 3.3 in my westfalia and the van fired right up and I was bleeding the coolant lines and the van shut off after about 15 mins of idling. I now get a code 11, crank angle sensor fault. I checked the continutiy between the sensor plug and the ecu and all was good. I will be replacing this in the next few days but what does this sensor effect? I get no injector pulse or no spark, is this what happens if the crank angle sensor goes? Thanks, Jon
  3. I see the OP has only three posts he's not an active member but, I'm having the exact same issue. Does anybody know what the issue might have been? Jon H.
