6
comatosellama last won the day on August 10 2018
comatosellama had the most liked content!
About comatosellama
- Birthday 03/06/1998
Gender
Male
Location
MSU
Occupation
Student
Referral
I think reddit
Biography
I love my fart can
Vehicles
87 BRAT, 21 Corolla Hatch
comatosellama's Achievements
Subaru Nut (7/11)
119
adapt distributor to EJ22 tips?
comatosellama replied to Steptoe's photos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Monstaru is the guy you want to talk to, I know he personally has put escort dizzys on ej22. Not sure if he still hangs around here Here’s a thread from a decade ago, not sure why or how this is what my brain remembers. -
89 GL wagon on Ebay went for $1375
comatosellama replied to azdave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Damn. I couldn’t ever work on my BRAT cause I was a broke college kid, and now that I have the money the parts aren’t there. I genuinely cannot find an EA81 rear diff to save my life. Guess I’ll have to throw it on an s10 chassis or something 😔 -
Been scouring the internet looking for a source on rear axle shafts and have come up short. Hoping to finally get my brat on the trails this year but I need at least 3 new rear CV before I can make that happen Additionally looking for a spare rear axle assembly, I welded mine up and need a spare before heading out into the woods - PM if you’ve got one for sale
Hello, My clutch and transmission have both decided to grenade, and I'm having a rough time determining which transmission can fit in my car. I have found a rolled over 2005 forester with what I need, but am not sure if the clutch slave and other things will bolt up between the 2005 and 2002. I know I will need the rear diff so the final drive will match (a welcome upgrade), but will everything else go together or are these too far apart? Thanks, CL
Hello, Currently I have 4 rims off a 92 legacy, 14x5.5 steelies and some 23x7x14 and 23x10x14 atv / rzr tires that I want to throw on my brat. Do you think those tires will fir on those rims? Thanks, CL
My impreza has developed a squeak ever since I got it back from the dealer. I don't think the squeak is suspension, it happens when starting and shutting down the car. Squeak also happens when car is off and you let the hood close with a decent amount of force, making me think it might be suspension. Jabbing the throttle and quickly letting off the throttle can cause the squeak. Bumps also cause the squeak. I took off both serpentine belts and the squeak was still there. Timing kit and water pump are fresh. Not sure what it can be, makes the car sound like absolute crap though :/ Heres the video Any ideas what this might be? Anyone ever had this squeak on their car? Sounds like it's coming from the front Heres the video
While the dealer was pulling up car after failed diagnosis, the car threw misfire for cyl 2 and 4 codes. I never saw these codes. Dealer says replace coil pack, plugs and wires with OEM. ( All good brands, under 20k old, plugs were already OEM). Picked up car after they replaced parts.Dealer says issue is fixed for the most part, just hesitates a little while going down the road. Issue came back within 500ft out of the parking lot. (I knew this would happen). Dealer work order shows mileage in and mileage out at the same reading, so they didn't even test drive it after their $450 "fix" before telling me everythign was alright. Service advisor takes my car for a test drive after I came back, and it did to him what I had brought it in for, after assuring me it was better. On my receipt for the coil/plugs/wires Dealer states front 02 sensor reading wrong, causing bad fuel trim, and rear o2 reading 0v. Dealer states they will not check into this issue because of my UEL headers. I ask why they replaced the other stuff without testing it just because it wasn't OEM, when they had a test saying something else was wrong. Again, dealer states they will not check into this issue because of my UEL headers, won't even try to fix it unless I get OEM headers and axleback back on the car. After a long discussion with the service advisor and his manager I got a full refund. I then walked to parts counter and bought OEM upstream O2 sensor, replaced it on the side of the street a block down the road, and everything is fixed. Annoyingly the O2 sensor I took out was an identical bosch unit as what the counter guy gave me, but this one works for now at least.
Did it for 3 or 4 quarter-half tanks at different gas stations. The issue started a little back in early September, then I picked up my 89 f350 and didn't drive the impreza until nov 3rd. Car pretty much immediately started acting this way, getting worse over time. I don't think the snow made it worse, it slid around just fine the first day or two of snow, now it's unusable until this is fixed. Drives fine at 3k rpm, hopefully the dealer isn't just throwing parts at it
Vacuum Advance for 1986 BRAT
comatosellama replied to Chip Hoppin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks like your link is wrong, could you link to the part page, not your checkout page? Been looking for one of these for a while! Thanks - CL edit : here is the right link. The website lists them as universal, please update on fitment! https://www.autopartsway.com/partlist.cfm?subaru/1985/brat/allsmd/allen/allb/ignition/secondary-ignition/distributor-vacuum-advance
