6
Everything posted by comatosellama
How'd you get to park next to that thing?
Put on the front lift. Removing the original struts took a 10 foot breaker bar and a lot of heat. Still need to source new top hats for the rear, the rear left is crunchy and dangerously rusty. Been thinking about making custom trailing arm droppers. How dangerous is just running a longer bolt through a peice of square stock? I'm pretty sure the answer is that it's not safe, just wanted some outside thoughts.
Ignition wire amps?
comatosellama replied to zombieblues's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Try using a relay. Should handle the volts better -
Have a question about the Crosstrek? Ask an owner!
comatosellama replied to subeman90's topic in Crosstrek "XV"
Couldn't you theoretically swap in a 2.5 from a new fozzy? -
2007 youtube was the best, What beats video responses?
Would love to see that. There's an svx near me that I kinda wanna do it to, if I had money
It seems like WCSS used to be cooler, especially when that guy had his lifted xt on like 32s
How high was your lift? And is it for sale?
Thinking about getting an 06 outback froma yard. Barely moves, would appreciate some help diagnosing Symptoms Coolant comes out of head at a noticable rate barely runs, doesn't really move apparently an exhaust valve or lifter is seized Was thinking new head gaskets, valves and lifters, possibly do the belts and water pump while I'm at it. Worst case just grab any old phase 2 and swap it in (using the 06 manifold)
The tires are matches, they're just off brand. (Diamondback MS) Problem with brakes it that it has a rear disk swap, and I don't know what car to order pads for
- 4 replies
- ej18
- spark plug
(and 1 more)
Tagged with:
1. Will ej25 plugs fir in the ej18? Have some brand new iridiums, would rather not have them sit. 2. I'm getting a whirring style noise with speed. It got a little better when I topped off the rear diff, but I'm worried it may be wheel bearings. Boots are fine. Tires are crap, as are brakes. Should I start with replacing the pads first before trying to get at the bearings? Also, I have nothing in the very back, like no spare, styrofoam or floor. Is the lack of noise insulation through there enough to make a loud whirring noise? Trying to upload a video I took with the noise Thanks - CL Edit: Answer to #1 is yes
- 4 replies
- ej18
- spark plug
(and 1 more)
Tagged with:
