Justcarolynn
Location
Anchorage
Referral
Google
Biography
Just trying to figure this car out
Vehicles
1990 subaru legacy
Justcarolynn's Achievements
Member (2/11)
0
I made sure the levels were good. It worked just fine and decided to have an outing with the bf yesterday up the side of a mountain (yes paved, actual road) but a lot of down shifting. He took it half a mile to the store... Everything was fine. I got in it an hour later to go to work.. Would not go over 20 mph revved up to 7k. Changed the knock sensor. Check engine light went out. YAY. Read the tranny codes after I figured out how and its throwing the duty c.... But everything I see says this won't be an issue of shifting. My parts store didn't have Chiltons nor could I find anything out about the "atf filter" that is mounted on the radiator. But everything is pointing me in the direction that its that filter that is probably clogged causing a lack of fluid to the tranny. Can I bypass that some how??
Thanks... Yes its a 1990 Subaru Legacy L.... Thanks I been reading this too... AHHHHHHHHHHHHHHHHHH then what is it. This is driving me crazy... Everything I read says the added on "twist on" atf filter but I can't find a part number or anything so I can see if my parts stores even have it. All I can find is the internal pan filter.
My car finally gave out. Will fight to shift up to 3rd gear but will NOT go into D. I changed the knock sensor... It was def toast.. But didn't fix the issue. Checked fluid.. Was low but is not anymore... Is red but dark red.. Don't see nothing sparkly in it. I checked codes again this time getting the "duty solenoid C". Does that code mean that the sensor is for sure out or could it be something else? Also what would that be listed under for the part because ive have searched and searched and can't find the part at o'riellys. I do live in alaska so my options are limited. I went ahead and put in the "lucas" oil in the tranny. Took it for a drive.. Still nothing.. Not sure what to do here... Have to report to work tomorrow night and I am carless. Trying to get this figured out before then. PLEASE HELP :-(
