2
Everything posted by 3Pin
There are two on car-part.com 100-139 miles away from you. On is $350, the other is $300. That is about the right price. Keep your core till it is done and change the spin off filter and drain and fill the donor. Change the rear main if you can while in there. Some guys say no need, but I always do. Sometimes they want a core charge, other times no. Ask ahead of time. Should be a 60-90 day warranty. I usually pick it up and try to talk them out of it.
pay the core fee and keep your trans until after the swap. I always seem to end up grabbing something part wise off the donor. If you are all done, and want to take the core back after and it won't cost you too much in time or fuel, then take the core back after you are complete. That is what I usually do.
Crank or cam position sensor. No start after a hot soak is the classic failure pattern for that type of sensor. It won't throw a code because the engine has to be running for the code to be stored. You can diagnose it for certain by measuring the signal with a voltmeter or oscilloscope when it's not starting.
Are you seeing coolant circulate in the radiator? Maybe you have blockage there?
- 10 replies
- blows cold
- no heat
(and 4 more)
Tagged with:
