2
Everything posted by 3Pin
I have had 2 95's with the 2.2 motor and just bought a 96 OB with a know HG issue. Once repaired with the new HG kit, it is my opinion that the 96 will be fine for quite some time. It had 152 K on the motor when it went bad. The 2.2 is a more reliable motor, that is a fact. If I were in your shoes, I would find a decent 95 or 96 2.2 Legacy sedan or wagon and ride of into the sunset.
I used Rock Auto for a bunch of misc parts and thought their prices and web interface was pretty good. Delivery was good as well Here is the folow up email they sent me extending a 5% diso************. Feel free to use it. I also used 1stsubaru recently as well. If you call 1stsubaru.com, they walk you through it and give you a good discount on genuine subaru parts. If you supply your VIN, they always get it right too. Thank you for being a http://www.RockAuto.com customer! To show our appreciation, we would like to give you and your friends a special discount on auto parts. Here's how it works: - You give the following discount code to friends, neighbors, relatives, the guy at the corner garage--anyone you know who works on cars or trucks: 370060346744 - When someone (including yourself) places an order at http://www.rockauto.com and enters your discount code, he or she will receive an immediate 5% discount on that order. * If you are using our Java Catalog, enter your discount code in the "How did you hear about us" line of the shopping cart * If you are using our non-Java Catalog, enter your the discount code in the "Discount Code" field of the Shopping Cart and click "Calculate Discount" - The discount code expires on April 4, 2006; so don't wait! You may use this discount code as often as you wish until it expires, but only one discount code can be used per order. **Each month we see people who put the word "discount" in front of their code and do not get the discount. Please enter ONLY the discount code.** Please call or email if you have questions or suggestions. Thanks again for buying your auto parts at RockAuto!
map sensor
3Pin replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I had a 95 2.2 automatic and a 95 2.2 manual. The automatic I think I had the same error, and I replaced the pressure sensor marked #4 in the previous usmb link. The manual 2.2 didn't even have a pressure sensor near the strut tower. Try a new spark plug, or wire to isolate the bad cylinder perhaps. -
map sensor
Check out this thread for a decent picture of under the hood http://www.ultimatesubaru.org/forum/showthread.php?t=51974&highlight=egr+solenoid This link talks about differences between a MAP and a MAF http://www.cobbtuning.com/tech/airflow/ engine type and year are kind of important. If you need a MAF, I have a used one listed in the classified area. Good luck! -
I had two 95's with 2.2's One automatic and one manual I sold one to my sister with 141,000 and the automatic with 146,000to a subie lover who answered the ad for the other. Both ran great. My sisters blows a little oil though when starting up. Other than that, 30 mpg still she reports. My 2.5 engine has 152,000, but has recently been out of the car for a HG repair. I'll bet both 2.2's won't suffer the same fate.
ditto to what color blind said. I just did a 96 OB with the same exact behavior. Mine had 152k. When they pulled the engine and looked at the heads and cylinder walls, my mechanic was amazed at the lack of wear in general. It is running great now. I would get the gasket kit from 1st subaru parts. They provide genuine parts at a discount. While it was out, we did the timing belt, water pump, seperator plate, cam seals ......you get the idea. It should be about $1200-$1800. Make sure you flush the radiator out well also. Good luck!
2.5 question
3Pin replied to pBIIKS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I agree with rweddy. If you find a nice subie and you can get it under market(my definition here would be market value minus $1,200 for the potential HG repair) pull the trigger. They are good cars and if you have to make the reapir then you do, if not store the green. I just bought one with a know HG that went at 150k and had the repair done. Hell, many other brands of cars are kaput at 150k. -
I Just bought a 96 Outback with 152K knowing that it had a Head Gasket problem, but the price was right. My local garage does great work and for a reasonable rate. They quoted $600-800 labor and just use my parts. While the HG repair is made, I am going to have the H20 pump done, timing belt,plugs, hoses, accessory belt, serpentine belt and cam seals done as well. Anything else recommended while this is all happening. I was going to get the 1st subaru engine overhaul kit with the gaskets and seals all included. Oil change and coolant also will happen after the HG reapir. Car has a new radiator. Poll time, will it take less time to pull the motor or leave it in with all of this happening?
