lancelincoln
Everything posted by lancelincoln
So, I hooked up a fuel pressure Guage. Image attached if I link it properly this time haha. Anyway, got barely 5 psi when I turned the key on (could hear pump running) and started the car and the Guage barely climbed to 20 psi. Hopefully I hooked up the Guage correctly. Also, the check engine light flashed when I pulled into the shop before testing the fuel pressure. I know that means misfire, so a faulty pump could cause misfire and lead to overheating? Hooked up right? Maybe a weak pump? I'm afraid to drive to oreilly again to use their scanner and my amazon Bluetooth scanner says no stored faults. I call bs as the light flashed and became constant. So, no codes to post tonight for you guys, but this is my progress. Thank you so much for the help so far.
I did the tube seals with the valve cover gaskets. I should add that the previous owner parked it 6 months ago and bought the timing belt thinking it should be done ASAP and didn't drive it so it didn't snap. He told me the car was hard to start for some time and I experienced that when we bought the car. 3 or 4 tries to start it to drive it home (only a block away) and 3 or 4 tries to start it to pull into my shop. I can remove and reinstall the timing belt in a couple hours no problem, just might not be the issue if it was preexisting.
I'll pull the plugs after work tonight. It's highly likely they're covered in oil as there was a couple ounces of oil in each tube when I did the valve covers. I used towels to soak up what I could. If they're oily, should I crank the motor with the plugs out to try and force out any residual oil in cylinders and tubes?
Side note, replaced fuel filter thinking that could be related to the uphill chugging and pinging. Car takes 3 or 4 tries to start and was like the before I did the timing belt. PO had the belt kit in the backseat when we bought it thinking that was the cause of the starting issues. Once it starts, it runs like a champ until it's under load.
Ok. I just did the timing belt/water pump, plugs/wires and valve cover gaskets. New scenario is that the car has no power and stutters under load, especially uphill. Got a code for O2 sensor, replaced and CEL went away. Car still chugs uphill and overheats. Could this be a bad cat? No water in oil and no oil in water. I'm stumped and about to push my Subi off a cliff. Any ideas? 2001 Legacy Wagon with 236 on the clock and completely stock other than maintenance mentioned above. Thank you in advance, you were all a big help on my timing belt.
I feel dumb. I couldn't see the notches and didn't think about running a small screwdriver around the gear. Passenger side one is under the white mark between the red and grey ones. Drivers side is on point right now. My timing cover only has marks above the crank pulley. You're also saying I should have the driver side lined up just to the right (closer to the fender) of where it is? I really appreciate all the help.
Sorry, looks like you can click the photo bucket links. I just want to make sure I'm in good shape before I finish up. Weird that I did a WRX belt a year ago with no questions and now I'm stuck on a much easier job, partly based on the multiple paint makings and no notched factory marks on the cam gears.
A little confused as my passenger side cam gear has many paint markings. Hopefully I'm able to link to photo bucket from my phone. Please let me know if things look good before I button things up. <a href="http://s1377.photobucket.com/user/lancelincoln211/media/Mobile%20Uploads/20140707_233207_zps09e17d17.jpg.html" target="_blank"><img src="http://i1377.photobucket.com/albums/ah52/lancelincoln211/Mobile%20Uploads/20140707_233207_zps09e17d17.jpg" border="0" alt=" photo 20140707_233207_zps09e17d17.jpg"/></a> <a href="http://s1377.photobucket.com/user/lancelincoln211/media/Mobile%20Uploads/20140707_233207_zps09e17d17.jpg.html" target="_blank"><img src="http://i1377.photobucket.com/albums/ah52/lancelincoln211/Mobile%20Uploads/20140707_233207_zps09e17d17.jpg" border="0" alt=" photo 20140707_233207_zps09e17d17.jpg"/></a> <a href="http://s1377.photobucket.com/user/lancelincoln211/media/Mobile%20Uploads/20140707_233207_zps09e17d17.jpg.html" target="_blank"><img src="http://i1377.photobucket.com/albums/ah52/lancelincoln211/Mobile%20Uploads/20140707_233207_zps09e17d17.jpg" border="0" alt=" photo 20140707_233207_zps09e17d17.jpg"/></a>
