thornleyjacob
thornleyjacob last won the day on August 8 2014
thornleyjacob had the most liked content!
  • Gender
    Male
  • Location
    Medford, Oregon
  • Vehicles
    84 Subaru Brat
Recent Profile Visitors
656 profile views
thornleyjacob's Achievements
USMB is life!
USMB is life! (4/11)
26
  1. I did a delete for the EGR. http://www.ebay.com/itm/EGR-Delete-Block-Off-Subaru-SVX-XT-Loyale-Brat-1600-1800-TBIM-/151393859173?hash=item233fc6f665:g:edwAAOSwHnFVmUlK&vxp=mtr Runs fine without.
  2. Going to be purchasing a lift kit this weekend for the 84 brat, just a 2". But I've seen a few members post that they have been able to use an outback components to extend the steering shaft, anyone got a part number for that? Or does anyone know the dimensions and spline count for the steering components? There are some places that sell some custom parts and I would want it matched up right. Thanks, Jacob
  3. FYI - I got my wheels on Friday and they look good. I am however going to paint the front face graphite and I still need to get tires for them. And a lift. LOL - so no pictures of them just yet. Anyone who is interested in the wheels should contact sales@get-primitive.com. They have 2x extra sets on hand.
  4. Thanks - will be taking a closer look at it this weekend and seeing if I can cure the issue completely.
  5. Seems to be a lot of different issues with idle these days; mine seems to be different. EA81 New Weber 32/36 DGEV New Throttle Cable Car runs fine while cold. During hot weather, or once the engine is warm, the throttle linkage does not return to 0. Checked accelerator pedal and pedal return spring; no play here when this happens. Played with throttle cable and cable housing while not back to 0; does not reset. Just touching the throttle linkage will make it return to 0; I visually confirmed that the linkage itself moves back to 0. I've taken the linkage apart, cleaned it up (even though it was clean), and give it a bit of grease. The only thing I can think of is that maybe I am tightening the bolt back down too tight? I only take it to the point that it doesn't wobble anymore. Really am stumped here.
  6. From my understanding, the boot is there to keep spoob like sand out of the grease... not really a container to hold that much grease.
  7. I just wonder if the left one will even work; the cutout for the bolt is larger, but also placed at a different distance from the lip. He may not be able to get the bolt through.
  8. The one on the left doesn't look right; not sure how else to explain. Maybe for a different vehicle?
  9. Will keep you in mind then; thank you for the offer. Probably won't be buying the lift until September. - Jacob
  10. And once I get my wheels paid for I will be placing an order Scott in Bellingham! Expect about 3-4 weeks.
  11. Both of your are right; his assumption that I meant shaft was correct. Your noticing me use the word knuckle when I meant only shaft. Editing above post to remove knuckle.
  12. If your buyer wants a slammed or stock Brat then yes; it can potentially decrease the value since they will have to work on the car to make it what they want. You are in Oceanside; I think you see more slammed/stock cars in that region than Lifted. Now if you were up in Ramona, it would be a different story. What the hell are you doing with the car anyways? Daily Driver? Hunter? Offroad? Me, I use my Brat for everything. I want it lifted so I can toss some larger tires under it, make it work better out in the muddy woods during Deer/Elk season.
