BirdMobile last won the day on July 17 2014
BirdMobile had the most liked content!
Gender
Male
Location
Salt Lake City, Utah
Vehicles
87 GL, 86 GL-10, 85 GL
BirdMobile's Achievements
USMB is life! (4/11)
42
I'm attempting the same thing - Weber plate sealing without a paper gasket - just sealant. My first attempt was with Permatex #2 type nonhardening gas resistant sealant. Too watery - the vacuum pulled it into the intake and I had major vacuum leaks within a week. Second attempt was Permatex #2 on the inside edges, and Anaerobic sealant on the outside (to keep the vacuum from pulling in air that would cause the #2 to "seep" toward the intake. This worked fine for about 6 weeks, then the same problem developed. I'm thinking the constant heating/cooling cycles with expansion/contraction causes the Anaerobic to eventually crack. My next attempt will be with Permatex Permashield (gas resistant polyester based RTV) that I just picked up yesterday. This stuff should (theoretically) be perfect - not as liquidy as the #2, and stays pliable (to handle the expansion/contraction). I'll keep you updated.
The documentation on these sucks. I would personally first verify voltage at the connector, then disassemble that section and look for dirt or other contaminates. Barring that, warrantee it.
EA82 digital dash differences
BirdMobile replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
85-86 Red Digi-dash 87-88 Green Digi-dash From my research, they are apparently not interchangeable, wired differently apparently. I'm going to be working on mine (1986) in a few weeks, I'll post anything I learn about it. P.S. Gary - did you get my email re: EJ22 ECU? . . -
weber 32/36 air filter
BirdMobile replied to justajester's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've searched and searched for a paper filter for my Weber. I've finally given up - I'm going to modify my old Subaru air filter box to attach to the top of the Weber, and buy the standard Subaru oval paper filter. -
Fuel Pump / Controller problem Hitachi ea82
BirdMobile replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check your fuel filters. -
Complete 4WD Axles
BirdMobile replied to JuhaKankkunen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Everything I've read seems to indicate that it's better to hold on to your OEM axles and remanufacture them. The aftermarkets don't seem to hold up. There's a thread "CV Longevity" on this forum that details it all. -
"The one to blame!" I hate AWD. And automatics. . .
Yep. These cars were from an era when quality and reliability actually meant something. Modern cars are about bling - "features", computers, DVD players in the back seat, "OnStar", and airbags and antilock brakes to save us from ourselves and our crappy driving. Car companies design everything on the edge now, squeaking every penny out of the mechanism until all that is left is just BARELY adequate to outlive the warranty. We are expected, as consumers, to buy a new car every 3-5 years, and in the meantime take our rides to the stealership for overpriced service if anything goes wrong. Engines are so complex now that you need thousands of dollars worth of specialy tools to even begin considering working on it yourself, for anything more than a simple oil change or tire swap. The last modern car I looked under the hood of was so full of computerized boxes and sensors, it's a miracle anyone has the patience to unplug all that crap from the 3,000 sensors before attempting to pull the engine. To hell with all that - give me an old, reliable, easy to fix mid-'80s boxy station wagon any day! Sometimes "progress" isn't.
Timing Belt or Timing Chain?
BirdMobile replied to Sapper 157's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Auto companies want you to buy a new car every 3 years now, and give their dealership (stealership) mechanics a ton of money until then. Old reliable designs like the Subaru EA series that you can work on yourself don't fit in well with that agenda.. .
