gunther4272001
Everything posted by gunther4272001
I just talked to the previous owner and they said it has always sounded like that as far as they know ( was owned by her grandma since it was new) so I'm thinking piston slap but going to check the timing tensioner anyhow. also going to run some seafoam through it to try to clean some sludge out of it being that it only has 34,000 miles on it maybe there is some kind of build up in it
there may be a proper way to it which i understand what your saying, all i can say is that is what i did and it worked can't explain why but it did. there is no evidence of a head gasket problem there is no coolent in my oil or in the tranny,no signs of leaking anywhere on the motor and the exhaust has no moisture comming out the exhaust or no smell of burning coolant. all I can say is it hasnt overheated since
update on the overheating got it fixed as far as i can tell . I couldn't get to stop overheating so my friend told me the only way he got the air out of his was to run it until it got hot and shut it down and lett it cool down till its cold.by some miricle it worked , just got done taking it on a 40 mile drive up hills and horsing on it and it never came over the middle of the gauge.thanks for all the input guys
I just installed a used radiator in my 98 legacy outback and it will run at normal temp. for awhile then it will start to overheat. it will push all the antifreeze into the resivor. if i release the pressure on the cap it will start to run normal again.every once in a while i lose heat for about 1 or 2 minutes and the antifreeze seems cold not hot. ive been told it sounded like a air bubble in the system any ideas?
having the car on ramps we got 5 qts. each change so i figured on doing one more . i was just worried about the detergents in the new fluid causing any of the old sediment that is in there to plug up the valve body ports. Was told it was a bad idea to do this by half the guys i talked to and the other half said it shouldn't be a problem , i guess time will tell. thanks for the all the imput on the topic
it seems like i fixed the shifting problem in my legacy. I ended up draining the fluid out of the pan and was going to drop pan to check the wiring for the selenoid. When draining it the fluid looked like black motor oil real thick, so instead of dropping the pan i just changed the 5 quarts i removed after 2 days must be the new detergents in the new fluid must have done something because its been shifting ever since. my question is I've already changed the fluid 1 time since it was a brownish red color should I do it 1 more time or should i just leave it alone seeing that it's running fine? Another question is it's running around 2500 rpm at 60 mph does that sound about right?
