Stevo F
6
Everything posted by Stevo F
I've got a 2005 Impreza Outback Sport and noticed there is no fuel filter under the hood to replace like our '98 Legacy has. Apparently around 2005, Subaru began to put the filter in the tank instead of under the hood. As the car has 151K miles, and probably the previous owner never changed the filter, I would like to replace it, if it is in fact a replaceable filter... Is there an actual fuel filter, or is it merely the mesh type sock that fits over the fuel pump intake in the fuel tank? If the sock is the only thing acting as a filter, should the sock ever be replaced or just replace it when the fuel pump is replaced eventually. If there is a filter, I'd like to replace it before the fuel pump itself gets clogged up and dies at some inopportune time.
I'm thinking headgaskets that are leaking oil will have more oily residue on the bottom of the engine. My '05 Impreza has a small amount of seepage coming from the bottom ogf the headgaskets, but not an oil drip yet. At 151K miles I think I have a bit more time before they start leaking oil steadily. I know the EJ253 (used in 2005) is known for external oil leaks at the headgaskets.
I have a 2014 Impreza Premium with the CVT. 18K so far and no issues whatsoever. Hasn't burned a drop of oil. High oil consumption was common on the 2012's, some 2013's and a few 20144's that I've heard of. I'm curious myself if the FB series engines in these cars will have headgasket issues down the road, but probably not enough high mileage ones at this point to tell.
Outback color
Stevo F replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If it's the dark green (Spruce Pearl metallic), I believe it was the same color from 1995- 1999. Same color as our 1998 Legacy (the middle car in my avatar). -
I've decided to daily our 2005 Impreza Outback sport on my 80 mile round trip commute. I really enjoy the car, so I'm letting my wife drive our newer Impreza sedan that has been my daily commuter. The car seems solid running at 150K miles (we've had it since 129K miles). I know the EJ253 version of the EJ25 engine series is more known for oil leakage from the headgaskets than anitfreeze leakage. There is a slight amount of oil seepage on our car, but nothing amounting to to an oil drip, so I think there is time before headgasket replacement. I'm wondering how many miles have people gotten out the EJ253 (2003- 2007 vintage Subaru's) as compared to the older engines. I know EJ22's are good for 300- 400K miles, and even some EJ25D's that didn't succumb to overheating are going over 300K miles. If I wanted to drive this car for another 5 years, could I expect to get 300K? (assuming I continue 3,000 mile oil changes and continue to drive like a grandma)
Actually when I bought the car at 129K miles it appeared the timing belt had never been done, som I was able to bargain on the price, but then had a mechanic do it right after we bought the car. Hopefully it will be many more miles before it gets to be a bad enough drip. My thought is if the clutch needs to be rdone at some point, I might as well have the head gaskets done if the pull the engine (like you, not going to try to do timing belt/ headgaskets or clutch by myself.
My car currently has 149K miles. We bought it at 129K miles two years ago, and I ha noticed a smaller amount of seepage, mainly on th driver's side when I was under there replacing the front subframe (the fierst one was rotted through thanks to the Pennsylvania road salt from where it came from). I'm wondering how long it might be before it starts leaking a lot of oil, or might it et bad enough to start mixing oil and antifreeze. I think the pics are viewable because of my Google settings so i hadded them to a shared album at the link below: https://goo.gl/photos/HJhH1yQTWv7Y2anQA
I was checking the bottom of the EJ253 engine in our 2005 Impreza Outback Sport and noticed some black oily residue on the bottom of the heads. I know this model is engine more likely have an external oil leak form the gaskets than internal/ external antifreeze leaks. It's not bad enough to be dripping any oil, but some residue on the bottom of each head and some residue on the center of the crossmember that goes under the rear of the oil pan (I'm thinking that's travelling down to the center of the crossmember from somewhere else. It's been a great car for the 20K miles we've had it, just wondering if this small amount of residue is the beginning of a bigger leak. I might think of getting something else (with an automatic) and let this one go if the headgaskets will need to be done in the near future. It doesn't appear to be coming from the valve cover gaskets. Below I've tried to put links to some pics I tried to get while I was under there (the darker areas are the oily residue): https://photos.google.com/photo/AF1QipPOBm89UtwyoDWHDfeFJsboWKDnqoDkEZh1QgHQ https://photos.google.com/photo/AF1QipNjJ_oJ6K0CQCBhsiLDVuuY71KganhG1fMFytaV https://photos.google.com/photo/AF1QipNjJ_oJ6K0CQCBhsiLDVuuY71KganhG1fMFytaV https://photos.google.com/photo/AF1QipNjJ_oJ6K0CQCBhsiLDVuuY71KganhG1fMFytaV https://photos.google.com/photo/AF1QipNjJ_oJ6K0CQCBhsiLDVuuY71KganhG1fMFytaV
If it is in fact an EJ253 (I would verify this with the seller) then it was most likely to have an external oil leak from the headgaskets, which you could live with for a while and plan on whne to repair it. If it's the original EJ25D engine, the headgaskets fail between the combustion chamber and the water jackets resulting in overheating and possible additional engine damage (these have a more sudden/ catastrphic failure than the later EJ251/ EJ253 engines). As for chcking for the overheating issue, check for bubbles and./ or oily deposits in the coolant overflow tank.
Car looks to be in decent shape. '96 Outbacks were known for headgasket issues. If the owner is correct that the engine is an EJ253, then it must have been swapped from a 2004 or so vintage Subaru, and would be less likely to have headgasket problems, but still might. In comparison, the engine on your '97 Impreza is an EJ22, which is on of the best Subaru engines ever built. If you are looking for a 90's vintage Subaru, I'l look at an Impreza, or Legacy L as these have the EJ22 engine which should go 300K+ if maintained.
I have a 2014 Impreza Premium. It's a great car (so far) after 27K miles. I have the CVT which gives me about 33 MPG in mostly highway driving. Time will tell how well the FB20/ FB25 engines last, but hopefully better than the EJ25's. It's true that many 2012 and some 2013 were known for high oil consumption issues, but mine hasn't burned a drop of oil yet. Our other two Subarus are a 1998 Legacy wagon (bought used, driven by my son-, will likely last forever), and a 2005 Impreza which is running well after 149K miles (not bad headgaskets- yet). I think nothing will beat the EJ22 engine that you had in your previous Subarus.
Thank you for your input. I saw an ad for a nearby 2001 L.L. Bean edition. I may go see it this afternoon: http://washingtondc.craigslist.org/nva/cto/5498590751.html Asked owner for some more pics. Seems like a good price if the car is pretty solid. Is there anything else I should be looking for on this particular model?
Will be looking for another used Subaru at some point (maybe an older Outback) with an automatic so everyone can drive it. Looking for something that shouldn't need major repairs (assuming it was properly maintained). I know the early to mid- 2000's EJ251/ EJ253 engines had few head gasket failures than the previous EJ25D, but they still occur with some regularity. Throwing around the idea that maybe the H6 would make a more reliable engine. Not in need of the extra power, but like the idea of a timing chain and reportedly fewer headgasket problems. My question is are there still a greater likelihood that headgaskets may go and how long should the timing chain, guides, etc... last? Also I know the H6 likes premium, but at 50 cents more a gallon than regular, I would likely want to run regular. Wondering how badly gas mileage would suffer if that were the case.
I've read where the coolant conditioner was recommended for early 2000's EJ251 engines. Your 2005 should be an EJ253, which I believe are more known for external oil leaks. Maybe wouldn't hurt to use it however. I also have a 2005 (Impreza Outback Sport) and I did notice a small amount of oil residue on the bottom service of the driver's side head, but not drips, after 129K miles when we bought it. It now has 148K and I still start checking it at each oil change also.
It would be a great candidate for a EJ22 swap as the body is rust free and clean. Problem for me is physically doing that large of a job (I'm pretty much a tune-up and brakes guy), finding a good running EJ22, and the seller is firm on the $1,500 price (although if a mechanic agrees on failed headgaskets that price could come down).
