Stevo F
6
Everything posted by Stevo F
My 2005 Impreza with 5 speed manual sounds similar. The clutch doesn't release until the pedal is to the floor and something is squeaking when the clutch pedal is pressed (I think it's the pivot bearing on the arm that is engaged by the slave cylinder. My clutch pedal is also lazy to come back up after you release it so I have a new slave cylinder on order.
After we bought our 2005 OBS last February, I noticed the manual shift would grind a little going into 4th. I ended up adjusting the clutch pedal so it pushes the master cylinder in a bit more, hence should allow the clutch to fully release. After this it seemed to help and it didn’t grind anymore. I did notice recently, that even with the clutch adjusted, it you pretty much have to push the pedal to the floor to fully release the clutch. Anything less than to the floor and the car is hard to shift. A mechanic I know recently said the clutch itself is probably worn out and will need to be replaced (I was wondering at the time if it was the transmission causing the hard shifting). I do not know the history of the car for the first 129K (the car has 134K miles now), nor do I know how the previous owner drove it, but I assume the clutch is original. The latest thing it’s doing is the clutch pedal is sometimes not coming fully back up to its rest position once you release the pedal (you need to pull it all the up with your foot). I know the clutch pedal mechanism in my old Nissan truck was spring loaded so it the pedal would always pop back into position once you let your foot off it , but the Impreza clutch mechanism (even when not connected to the clutch) seems to pop all the way in pop or all the way out. This morning the pedal was stuck halfway down after release it, and only when I pulled the pedal up did it pop back into it’s normal released position. I tried to lubricate the clutch pedal mechanism which seemed to help a little. So is all of this indicative of a failing clutch, or clutch pedal mechanism, or the hydraulics (I did flush the fluid out of the hydraulics clutch a few months back, but no change in pedal afterwards, so I assume there no trapped air causing an issue.
I haven't gotten around to changing the transmission oil yet, but have noticed more issues with my clutch itself. I've adjusted the clutch pedal so it is engaging the rod to the clutch master cylinder farther in, so the clutch should disengage the transmission when the pedal is higher, but it doesn't disengage until almost to the floor. The transmission has been fairly smooth to shift if you have the pedal to the floor. Last week, I also noticed the clutch pedal was sluggish to come all the way back up. I lubricated the clutch pedal mechanism where I could and it seemed to help. I got in the car this morning (after my wife had driven about 100 miles on it yesterday) and noticed the clutch pedal now barely comes off the floor unless you pull it up with your foot (you could still engage and disengage the clutch but the pedal is almost to the floor at all times). Of course she didn't notice it when she was driving it, so I hurriedly got in the new Impreza so I wouldn't be late for work. I was already was thinking of having the clutch replaced anyway, but what causes the clutch pedal to release?- is it the clutch pedal mechanism, or something in the clutch assembly itself? Could there be an issues with the hydraulics (clutch master or slave cylinder)?
cvt trans
Stevo F replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There is no interval I'm aware of to change fluid on a CVT. I'm thinking like 60K miles and use Subaru fluid. I only have 4K on my 2014 Impreza, so that's several years off for me. -
One big like for my new 2014 Impreza is with the CVT I am getting 32- 33 MPG on my 80 mile round trip commute which rivals what my 2007 Corolla used ot get. But this car is always in AWD, is heavier (which holds the road and outhandles the Corolla). Dislike about this car is it seems complicated, not as easy to work on.
Actually the exhaust heat shields rattled like crazy when I first got the car. I stuck pieces of coat hanger in them and they haven't made a peep since. I listened to the noise again, it's not terribly loud, but noticeable if you stand in front of the car. I pulled the drive belts and it didn't go away, so it's in the engine somewhere.
Timing belt was last done 12K miles ago. Idlers, seals, water pump were all done at that time (right after we bought it since I didn't know when the timing belt had last been changed). I feel I've heard the noise before, but it's noticeably louder now. I feel it is coming from the drivers side timing cover area, but I may pull off the drive belts to eliminate the A/C compressor or idler pulley from being the culprit.
1998 legacy L, EJ22 engine, 4EAT transmission, 103K miles. My son has been driving the Legacy for the past couple of months back and forth to school. One thing I need to do is replace the front driver's side caliper (the brakes are running hot), but couldn't break loose the upper caliper bolt, so we took it over to a friend who runs a garage and they broke loose the bolts and snugged them back up last Monday, so I can get to the caliper this weekend. No problem there. Then this morning my son tells me that car feels a little jerky when he is braking (he says it like it's changing gears). I figure maybe the caliper's a little loose and I'll take of it tomorrow anyway. Then there's more... when he got home tonight my son pointed out that sometimes the engine doesn't catch right away when you crank it (sounds like like it's half starting for a couple of seconds) then it fires up and runs OK... Then when I tried starting it again to duplicate the not catching right away issue I noticed the idle won't go below 1,500 RPM even at operating temperate. I wonder if that's related to the starting glitch? I checked under the hood to make sure all vacuum lines looked OK. My son told me all of this started Monday after we had the caliper bolts loosened (and they were never under the hood). But wait, there's more. When I was poking around under the hood I could hear a pretty noticeable ratting coming from somewhere on the driver's side front of the engine. It's not rhythmic (like a bearing noise that is timed with the engine) but the rattle is irregular. What the heck is happening with this car? Not blaming my 17 year son for any of it, but I miss driving it everyday where i would notice any irregularities right away. There were CEL's then , but I decided to do an ECU reset. Afterwards, the engine seems to start and run normally. While resetting all of the stuff on the radio, it threw a CEL (which stayed on after multiple restarts). I need to get an OBD2 code reader I guess. Actually I few weeks ago my son got a CEL, but it went away and didn't return until after the ECU reset
Seems like it's always deer season around here (central VA)- just a bit more in the Fall. I will also recommend an alignment as that will point out if you have any suspension damage. Also looks your car has good ground clearance, which i'm sure helped. Our '98 Legacy and new Impreza sit so low (too low for me personally).
If the low vehicle is also an issue I can understand (I have a 2014 Impreza also) and I think the car is too low, at least for me personally. I've seen where spacers can be installed at the top of the struts to give 1" or more additional ride height. I'm thinking of going that route sometime myself- just not sure I'm up to doing the work myself.
We picked up our 2005 Outback Sport for a reasonable price. The N/A EJ25 still has enough power to get around and is still a simple engine to work on. I believe there were fewer (although still some) headgasket issues starting in 2004- 2005 than in 2002- 2003. I know what you mean about the newer ones being way too complicated. The electronics on our new 2014 Impreza kind of scare me.
Thank you- Are you tihnking of this set? http://www.ebay.com/itm/2012-2013-2014-Subaru-Impreza-LED-Fog-Lamp-Driving-Light-Kit-Set-sedan-hatchback-/321444642860?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2014%7CMake%3ASubaru%7CModel%3AImpreza&hash=item4ad798002c&vxp=mtr If I get these, I still will need the relay and the replacement lower dash panel with the switch for driving lights. I assume I can still get these separately, outside of the complete kit that Subaru sells
Thinking about getting the driving light install kit for my new Impreza. Wondering if they'll do a lot of good for me. Looks like since they illuminate the area right in front of you better, they may be better for driving in fog or falling snow (where high beams just reflect back at you). My biggest issue with night driving (and will soon be doing a lot more of that with the days getting shorter) is all the deer we have around here- not sure it would help me see them better. In any case I like the look of the lights mounted on the car (vs. the blank that's installed in the holes for them now)- just not sure it's worth $270 unless they improve visibility.
I've thought about the oil (also back when it was grinding a bit in 4th). I'll likely go ahead and replace it since it is probably a needed maintenance anyway. It was not better driving to work today, really. No issues until pulling into the parking lot at work- had the clutch in while slowly going around a turn (getting around some goof who parked a semi in the road)-it didn't want to to go into second at all and ground a little when I pushed it in a little harder than it wanted. Does the Subaru Extra S oil generally help for smoother shifting, or if the synchros are getting a little wanky? I've also heard people recommended the GM Synchromesh "Friction Modified" ol as well.
Parts Question
Stevo F replied to MDub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That's the fog light surround- I think it only has some clips that hold it in. -
I rechecked the fluid levels to make sure. Clutch is fluid is good (I recently changed it out as the old stuff was nasty). The transmission oil looks clean (not sure when last changed as I've only the car for 7 months) and is up to full. I did have an issue a few months back where I would get some gear grinding going into fourth. I tried adjusting the clutch pedal so it engages the clutch a little more and that problem went away. Thinking it might be a linkage issue, tonight I popped off the surround around the shifter and removed the shift knob and boot. I lubricate the pivot point of the shifter. It now feels a little easier to shift (I drove it around the neighborhood a couple of times shifting between 2nd and 3rd a lot), but I'm not sure something still won't start binding again. I guess I'll try driving it on the 80 mile round trip commute tomorrow and see how it does.
I driving our 2005 Outback Sport with 5 speed manual around today and felt it was getting harder to shift into various gears (especially 1st and 2nd). It got so bad by the time I turned into our street to go home, that it wouldn't go into any gear easily so I coasted it on into the garage. A few minutes later, it shifted smoothly through the gears. There was no grinding or any other issues once it went into gear- it just is taking a lot of force to shift. My thought is that it's an issue with the shift linkage- is there periodic lubrication of the linkage needed, and if so, how is it done?
