Stevo F
5
Everything posted by Stevo F
Glad it worked well for you. I think that method worked best for me too. I've done all 4 of our older cars in the past year. I also got a brake bleeder and started flushing brake fluid as I hear that should be done every 3- 5 years (the 2 Subraus done, still need to do the Sienna and the Honda). I realized you should flush out power steering fluid periodically when I had a steel power line rust out and leak on my old Nissan truck (mind you it was 16 years old at th etime, but it was a very that wasn't used every day so I'm sure the moisture got into the fluid over time and rusted the lines out).
Any of the EJ22 engines after the 1996 model year interference so bent vales are likely. if no piston damage, a set of used heads may be the best way to go. I also agree that if you have to pay for the work to be done, the cost will go up tremendously. I have spent way to much on our '98 & '05 Subaru's paying for a mechanic (even at only $70/ hour) to do the work.
You actually shouldn't need to run the engine to use the P?S pump to pup the fluid out. I usually disconnect the return line to the P/S reservoir and put in a container to collect the old fluid, pout the fron of the vehicle up in stands, and turn the steering wheel from one side to the other a few times. The steering rack will push the old fluid out into the collection container. Refill the reservoir and repeat several times until you begin to see the new fluid coming through. I've changed out the steering fluid on my of our cars the past year and each car was a little different. I used the above method on our 2006 Sienna van (original fluid was yucky) as well our 2005 Impreza. Last year, on the '98 Legacy, I couldn't get the return line off (and this car has the reservoir integrated to the pump, so i used the less desirable turkey baster method to suck out the old fluid, refill, run engine and repeat. With this method, you tend to suck out more of the new fluid, so it's more wasteful. On my son's 2001 Honda Accord I tried disconnecting the hose and running the engine and that seemed to work well but I ran out of the special Honda P/S fluid before I truly had the old stuff flushed out.
I tried the lithium grease. I didn't have a bendy straw, so I used an old piece of vacuum hose. I stuck the hose down until it hit the pivot joint on the release fork I squirted some of the grease down the hose until it came out the bottom. Afte rthart tried the clutch and it's been quiet so far. Thank you for your help.
I think I nailed this down. When going over a 2" lip at the entrance to the garage, the car would make the noise, but it sounded like it was under my feet, towards the front. When I had the car up on jack stands I went under and checked the bolts holding the front subframe I recently replaced. One on the passengers side toward the back was a bit loose. Tightened it up and so far, no more noise.
The person who started the thread has a 2013, and I have a 2014 but they are the same car. Thank you for sharing these threads- it looks like other folks with the 2012+ Impreza's have asked the same question. For me, I might look into the 1" spacers (seem like they'd be inexpensive and easy to install and no radical suspension geometry changes.
Interesting article, but not sure if holds true for 4th gen Impreza's or not. I just bought a 2014 Impreza and am disappointed with how low the stock ride is. Even had to buy a set of ramps to change the oil (which I never needed for my '98 Legacy or 2005 2nd gen Impreza). I, too, am concerned with how this car would drive in more than several inches of snow. I know that the 1st & 2nd gen Impreza's (and maybe the 3rd) never seemed to sit this low.
good deal?
Stevo F replied to skidrock's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You mainly need to worry about headgaskets if you have the 2.5 liter engine from 1996- 1999 (if you have any Outback or GT). If you have a Brighton or "L", then you should have the 2.2 liter (phase 2) engine which nornally doesn't have any more headgasket problems than other cars. -
Since we bought our 2005 OBS 6 months ago, I've noticed that both the clock and radio illumination seem dimmer than other cars. They are barely visible on brighter days, and if you need the headlights on a rainy day they dim like they are supposed to, but the displays are almost dark. I'm familiar with the illumination control for the instrument panel, but is there any way to adjust the clock or radio illumination?
Just wondering if it would be counterproductive to drive our new 2014 Impreza on a long trip 600 miles- (300 miles each way- mostly 70 MPH driving on I-95) with the original oil still in the crankcase. The car currently has 1,900 miles on the clock (so it's well over the 1,000 recommended break in period). I was planning on changing the oil at 2,500 or 3,000 miles for the first change and 4,000 miles thereafter (since I am running synthetic- I've always changed conventional oil at no more than 3,000 miles and less if it's a vehicle that's not driven daily). The car should have just over 2,500 miles when my wife returns with it. I'm just concerned that that amount of high speed driving with the original oil could cause more harm than good, so I'm thinking about having her take our van instead (which will suck up 2X the amount of gas, unfortunately). I ordered some Subaru oil filters which will be here next week, so I'll likely change the oil soon regardless.
I know they did away with the automatic (replaced by the CVT) on the Impreza by 2014. I also got the Premium version because it at least has the paddle shifters (I found out the base version with CVT doesn't have them). I need to be able to downshift manually when the snow and ice return. I like the CVT takes a little getting used to the acceleration curve, but good MPG's (any Subie that averages over 30 MPG is good by me). Still like driving the 5 speed manual OBS on days when i don't drive the new one.
I thought I heard for 2015 they were reducing the oil change interval from 7,500 to 6,000. I never go that long anyway with my cars. I normally go 3,000, but running my new 2014 Impreza on synthetic oil, I might go 4,000 (it only has 1,600 miles so far). As for doing the first oil change at an earlier interval, I've heard varying opinions on that, including that there are additives in the crankcase from the factory that may help to run in the engine for at least 1,500- 2,000 miles or more. I've never done the first oil change early on any other new cars I've had, so I likely won't on this one either. I'm dismayed that there are two recent threads in this forum about problems with brand new 2014 Impreza's- mine has been great so far, but will some issue rear it's ugly head? I plan on letting my wife drive the car by herself on a 600 mile round trip next weekend because all our other vehicles are older (or lots worse on gas). I would assume since it's new- nothing to worry about yet.
Nope, didn't see anything weird under the car. My son who was riding in the back seat said it sounded liek it was coming from right below them, but nothing under the car was amiss. I usually hear it when braking so I suspected something with the brakes at first. then I heard it when the front passengers wheel went over a 2- 3" concrete lip going into the garage, so I'm thinking suspension?
Thank you- Have to pick up some of the Lithium grease. Definitely don't want to mess with the hydraulic line to the slave cylinder as I decided to bleed it out this past weekend and had to pull the master cylinder away from the firewall before the rod would clear the port in the master cylinder to allow air and fluid to bleed out.
