Stevo F
5
Everything posted by Stevo F
In my previous post I mentioned my cooling fan wasn't shutting off once it kicked on. I replaced the coolant temp sensor with no change. I took it to my mechanic who tested the electrical side of things with the fans and concluded the ECU was not calling for the fans to cycle off. I also opted to have a coolant flush and fill and put in a new OEM thermostat (thermostat hadn't been replaced that in the 6 years I've had the car). My mechanic did this work and noted that the coolant flow was very poor in my radiator and likely was clogged up. He also noted that once he was confident all the air was out of the system (he has a device that sucks all the air out) he was seeing a stream up bubbles coming out of the radiator, but only when the engine is revved up, and not at idle. I then returned with one of my spare radiators which he installed. He reported the fans are now cycling properly, but the air bubbles still remain. The car has never overheated and no oily gunk in overflow tank or anything like that. He is thinking early signs of headgasket failure. I know it's rare on phase 1 EJ22's, but not unheard of. Are there any other ways to better identify if it's headgaskets? (I plan to drive it some to see if the air bubbles are still coming up to make sure it's not just trapped air). It's getting close to needing the timing belt done anyway, so I'm thinking it may make sense to do headgaskets too. If so, what are recommendations for good MLS headgaskets? Did Subaru ever produce them, or are OEM EJ22 gaskets all single layer?
Thank you for the input. Sounds like front seats are no issue but the rear seat is more tricky. The question is will an older Impreza rear wagon seat fit? (I see seats from a ‘99 Impreza for sale locally). Also wondering if anyone has put a 1st or 2nd gen Legacy rear wagon seats in a 2nd gen Impreza wagon
Never heard of a car company doing something like that... I know Subaru is pushing folks a lot harder than a few years ago to replace the airbag inflators. Since I picked up the 2005 Outback Sport last year, I've gotten numerous notices from Subaru about the recall, one even offering a discount on parts. I also received one form the DMV. I'd get it done but the car just sits in the yard and there no convenient Subaru dealers nearby. In my case, if SOA sent a guy over to the house, I'd probably say "have at it"
If Foroester sears will bolt in, or bolt up to my Impreza risks I wouldn’t mind them. I really like the seats in my 2003 Forester but I believe all of them have airbags and I don’t want to mess with that since my car doesn’t have side airbags. over at the 2nd gen Legacy forums I’ve read that WRX (aka 2nd gen Impreza) wagon seats will fit both front and back into 2nd gen Legacy’s, do Om wondering if they will swap in the other direction.
The seats in my 2005 Outback Sport wagon have seen better days. Interested in swapping both front and rear seats from another Subaru wagon but curious what would interchange with little modification. Im guessing no issues with seats from any 2002- 2007 Impreza or WRX wagon. Would seats from 2nd gen Legacy or Outback fit? Also curious what generation Forester seats might fit.
Update- Today decided to swap all wheels and tires with my '98 Legacy GT to see what would happen with the vibration. Both sets of wheels and tireds are the same size, both have about 3k miles on them. The vibration at around 45- 50MPH was still there a little bit, but just barely noticeable. I then drove the Legacy with the Impreza tires and felt a little bit of vibration or maybe just road feel, which may be the cheaper Sumitomo tires, or maybe one or two tires that weren't balanced well when installed. Also, while I had the Impreza up on stands, I examined the driveshaft and u- joints. The driveshaft turned smoothly by hand and I could not observe any play with any of the 3 u-joints when turning it back and forth, and changing direction. There was some play in the transmission and rear differential, however.
One question that pops into my head regarding u-joints- wouldn't I expect the vibration to be less when the driveshaft is not under load (just spinning with the rear differential) when i put the car in front wheel drive? In comparison, the whine from the rear differential goes away in front wheel drive.
As a follow up, the vibration I felt on acceleration went away when the new front axles were installed (the old ones had flung a lot of grease out of the inner CV joints). The whine from the rear still persists but practically disappears when in front wheel drive only. I also get a slight vibration at highway speed that doesn't vary on turns or whether in FWD or AWD. Wonder if both symptoms could be wheel bearings, and if so, how to check to be sure (since they are pricey for my mechanic to replace).
Took it on a long drive the other day. The vibration is most pronounce around 50- 55 MPH. I put it in FWD briefly but doesn't seem to change when I checked it this time. Doesn't seem to vary on turns. It's just there. I had been thinking driveshaft u-joints, but I would think that would have diminished some when in FWD and not under load (like my rear differential whine does).It also doesn't seem to be worse when under load or accelerating. U-joints is my main worry (in case it decides to randomly self- destruct going down the road) otherwise it's not really bad enough to really worry about when driving. Just hoping it doesn't result in some catastrophic failure if I can't diagnose it right away.
I recently did a coolant change on my 2008 Forester X, auto transmission. I was smelling coolant and had to top it off a couple of times (thin king maybe some residual spilled antifreeze and needing to top of because of a few air bubbles surfacing) but tonight I noticed some wetness around the seam nea rthe top of the radiator where the top tank joins the core soo I'm thinking a small leak has developed at the seam. I'm guessing there is no effective way to repair it so it looks like I'll need a new radiator. Any recommendations on radiator brand or where to buy?
I piled around a bit and easily found the sensor once I removed the vacuum and front coolant hoses from the IACV and removed the intake from the MAF. I was trying to see if I could disconnect the connector and ended up popping the plastic part of the sensor out so it looks like I have to replace it anyway. I decided to order one from Rock Auto which will arrive tomorrow, so we’ll see if it fixes the issue- if not I’m out $11 for the new sensor
I've noticed that when I shut off my wagon ('98 Legacy L with 2.2 liter & automatic) I can hear the cooling fan shutting off as well. Sure enough the fan on the passenger's side is running any time the engine has warmed up, even on a cold day. It's been doing this for a few months now. I'm thinking the coolant temperature sensor is causing the fan to kick in at too low a coolant temperature. Otherwise the cooling system is in good shape- the engine temperature is right where it should be and doesn't fluctuate, no coolant leaks, etc... My problem is that I can't find the sensor. I've read up on it and seen some pictures online, but none of the pics look like what's on my car. I know it's on or beneath the intake manifold, near the IACV and the sensor for the temp gauge is next to it. Does anyone have a better way to locate it on an EJ22, or have some pictures showing it's location?
I actually have a spareclock spring from my '98 wagon. Is there a wayt to access the connectors to the clockspring without having to pull the steering wheel (like by removing the steering column molding). I'd like to find an easier way to connect up my spare clockspring and see if the code goes away.
Thank you. The FSM is very helpful. I was able to pull, the error code of 12 again (I found the two wires with pins attached wrapped up in the wiring under the dash). Plugging one pin into slot one on the connector will generate the error codes and plugging in the second pin into slot # 2 when the air bag light is blinking the codes will clear stored codes. Unfortunately mine didn't clear so the code is still active. For the seat to seat comparison, are you thinking of connecting the ohmmeter between the the connectors under each seat? The only issue there is that there is ony a connector under the driver's seat on my '98 and no wiring under the passenger's seat, so i don't have a second connector to connect it to. Also, is the roll connector the same as the clock spring? If so, I've had others suggest a broken clock spring is one of the most common problems and the roll connector is a possible cause for code # 12. The problem I see is getting a more detailed diagnosis. I was discussing it with a family friend who used a to bew Subaru mechanic (and still works on a number of them) who I'm hoping can help me pin down the exact cause.
