Sawspa
Location
Coolville ohio
Referral
Scot Russell
Biography
My first subaru!! Also own a 78westy that I'm pretty proud of.
Vehicles
1990 legacy ls
Sawspa's Achievements
Member (2/11)
3
It ran fine for two or three days. Then it started again, today it overheated twice, then the third time it seemed to be running fine with only letting it cool off for about 10 minutes. It gets a miss or something when overdrive kicks in or you let it idle down while driving. It also happens at the same time the overheating starts. Could this be a bad coil or spark plug? If it was a head gasket would it get better all of the sudden like this?
I opened the bleeder vent and finally got it filled up to the top and put the bleeder vent screw back in. Still didn't get me any heat though. The PO has put a flush port in one of the heater hoses. I am gonna open it up tomorrow and see if that helps get any air out. Do I need the car on very much of an incline? It's being finicky I guess. Most likely, it's operator error!
Ok! Got the timing belt, all the pulleys and gear replaced ( full Gates timing belt kit) and the water pump and thermostat plus radiator hoses and the bypass hose. It took me a while but I got it. Fixed a leaking hose today. I hope it fixes my issues. BUT. I got no heat! I think I might have a bubble in it. What's the trick on that?
Copy that. Wanna recommend a full timing kit name brand or two, and who sells them. I am sorry, I'm new to the subaru game. I don't recall the receipt I found said anything about the tensioner as a separate piece. I bet they did the pulleys and not the tensioner. If I do it, I'm going to do the wp too.
