Location
Tampa, Florida
Referral
none
Vehicles
1979 Subaru Brat, 2011 Subaru WRX
G14 James's Achievements
Member (2/11)
0
79 transmission input shaft seal.....WFT
G14 James replied to G14 James's topic in Historic Subaru Forum: 50's thru 70's
thnaks, Guy at NAPA told me same thing, guess it just a moremodern seal VS 30 year old seal. just wanted to be sure since its a lot of work if it leakes -
The seal with the meatla ring is the original seal NOK AE1032F and the other is suppose to be the replcement Timken 222050. It is quit obvios the its not the correct seal. Does anyone know the right part number for this seal? and where to get it? Any help is appriciated since i cant put the transmission back together till i find a new one.
i have the same problem with the seals and finding a sutible replacement, i was considering walking around a salvage yard till i find somthing close.
so i have put in a new alternator, new battery, new battery cables and purchased a new voltage regulator, after it was installed it seem fine until the vehicle is started at which point it begins to smoke. I put the old one back on and it works fine. is there a way to test them to see if the old one has already burt out what the new one seems to be working on burnin out. Or could they have given me the wrong one. The connectors are all the same just the internal look a little different but i thought maybe that would be just upadted.
Starting the journey to find a Brat.
G14 James replied to Seventy7's topic in Historic Subaru Forum: 50's thru 70's
i Live in Florida, found mine (1979 Brat) on criagslist in Arizona for $1000 and it runs and drives, cost me about $800 to ship it from there to FL -
im going to assume that there are no oem replacment radiators avialable anymore for the first gen , if the are where. Has anyone found another radiator that is a good replacement. The one i have is repairable but might be a better idia to just find another that wil fit.
i have a 79, heard the slack is normal. Mine has alot. not sure on body panels
1979 Brat Headlight or headlights?
i have the grill, guy i got it from gave me three extra and one was the 4 headlight, i would just need the buckets and brackets but havnt decided which looks better
