I know this is going to sound a little anal on my part but you used the term "bleed". Bleeding brakes is to get air out of the brake lines and components. If you are just going to replace the fluid and do not have air in the lines, then the correct term is flush.
The reason I point this out is that if flushing is your goal, then there is an easy way to do this that you can do by yourself. Get some clear 1/8" vinyl tubing at the aquarium section at WalMart. With the vehicle jacked up and on jack stands and wheels removed (easiest way IMO, attach a piece of the tubing to the bleeder valve. Note: if you do not have the correct size flair wrench, then use a box wrench or socket on a breaker bar to crack the bleed valve loose first.
The tubing should go upward at first a few inches, then into a jar of some kind, but it is important that it go upwards for an inch or two first to prevent any air from siphoning into the calipers. I also like to pack a little grease around the threads of the bleeder at the base, but that is not really necessary for this type of flushing. Now use a suction bulb of some kind to draw out all the brake fluid from the master cylinder reservoir. I use a suction bulb for batteries from a car parts store but you can use a turkey baster if your wife doesn't catch you. Refill the master cylinder reservoir with fresh brake fluid, your choice although I recommend that you not use any brake fluid meant for racing. Racing brake fluid absorbs water much faster than regular Dot 3/4. Racers usually change their brake fluid after every race and those who use their cars as street/track often swap between the fluids at the beginning and end of each race.
Now all you have to do is to open each bleeder, one at a time or all for together and let gravity do its thing. Only open the bleeders a little, especially if you do all four at once, because you need to keep the master cylinder full. If it goes empty, then you will have to bleed the brakes. I usually do the two at the back first, then the two at the front. Since this has a X brake pattern, it does not matter which side goes first, just rears first, then fronts.
