Everything posted by ducunee
I'm having same problem did you resolve?
Paper model Subarus
ducunee replied to Scott in Bellingham's topic in Old Gen.: 80's GL/DL/XT/Loyales...
looking into the same problem previous radio hack job. Have cassete deck that the plug hooks up
91 Loyale Fuel pump failure - replace with Ford pump?
ducunee replied to jsyme's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If running a weber be sure to check fuel pressure- 15 replies
Put in freezer overnight
1991 Justy wheel bearings?
ducunee replied to Zacharyhelm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There's a video posted showing bearing replacement. search forums for it. -
85 BRAT Have no speed indicator just hangs below 0. Odometer works. Where to start?
Viynal paint color for blue interior
ducunee replied to Downwash77's topic in Old Gen.: 80's GL/DL/XT/Loyales...
SEM Color coat in tan worked well for me. Don't know what colors are available, got mine at a auto paint store. -
*..Trying to locate old Brat?..*
ducunee replied to bakerman1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you have Vin buy a càrfax -
On my 85 trim just snaps on, no plastic
Check that the radiator is grounded. Top bracket should be soldered to radiator, very common for the bracket to break away.
- 10 replies
- 1
- Cooling fan
- 1985
(and 1 more)
Tagged with:
Have 85 BRAT at dealership to diagnose noise from rear, always run in 2WD. Conclusion that u-joints were bad. Question, does drive shaft turn when NOT in 4WD?
Clicking sound under body, ignition on...?
ducunee replied to beamsbox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Electric fuel pump? -
parts for exhaust~86 Brat
ducunee replied to Bratmobile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
got mine for 85 from rockauto -
Could a bad bearing cause the noise?
- 5 replies
- brakes cv joint
- pump
(and 1 more)
Tagged with:
85 BRAT. Starting out by backing up there is a grinding noise that sounds like worn brake shoes against the drum, checking those they are good. the cv joints are original (103K miles) and no visable sign of grease leakage. No driving problems not in 4WD although there is constant noise from the rear. Also any way to reduce the sound coming from the fuel pump mounted to the frame?
- 5 replies
- brakes cv joint
- pump
(and 1 more)
Tagged with:
Used bondo, and sanded
Window cranks, '84, how to remove?
ducunee replied to mkoch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is a slot under the crank arm. I formed a small "L" in coat hanger wire. Put flat bladed screwdriver on the plastic rig to give more clearance and hooked the spring clip out. -
Rust at center. Of roof fun top brat
ducunee replied to kgrove56's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pulled out headliner cleaned and put rest conversion covered with strip of fibreglass and bondo in the holes. Good luck. Always rust from inside out. -
This is the paint I used. Jamaica Blue (GM Europe) Numbers on can RSB-17988S Primary code 21Q Secondary code 2SU Mixed by auto paint shop spray can for $22
Had a custom mix. When I get back home next Sunday I'll send u the formula and a automotive paint shop could mix for u.
Can you buy new Brat rockers online?
ducunee replied to ragingbull's topic in Old Gen.: 80's GL/DL/XT/Loyales...
mill supply has rockerers for 4 door. don't know if they could be modified to fit. -
Walmart 3m trim tape. I put more mine on with automobile goop adhesive.
Sent you a message
