Hi folks,
New member, first post, hoping someone can help!
I bought a 11/2002 Subaru Outback 2.5 Manual and have a vibration issue.
From 0-30mph it is smooth, from 31-37mph there is a bad drumming and body vibe felt everywhere including a small amount in steering wheel. It occurs under load - no load - any gear - out of gear - brakes on or off - straight ahead or cornering but go over 37mph and it largely disappears.
This is a list of troubleshooting I have performed so far...
1) Two new tyres fitted and dynamically balanced on front, rears 50% tread - dynamically balanced
2) New brake pads and rotors all round - adjusted park brakes for no drag
3) All wheel alignment
4) Checked wheel bearings - no play
5) Switched front tyres to rear
6) Dropped tailshaft - u joints/centre bearing good - no play/notches
6) Swapped tailshaft from another car
7) All CV boots intact - minor play in inner joints - no clicking outers
I used a gopro to take under car videos at the vibe speed and found the entire rear diff + yolk and rear portion of the tailshaft is oscillating. The centre and front of the shaft is running true. I jammed spacers into the voids on the rear diff bushes and it made it a lot worse. Could it be the diff?
Sorry for the long post but I have been searching google for the last month and don't seem to find the exact same issue with a solution.
Cheers,
Simon
