danielzink
Location
Lansing, Michigan
Vehicles
EJ22 Powered Sandrail
danielzink's Achievements
Member (2/11)
0
Hey All, Title kind of says it all. I have a 99 Forester with the SOHC 2.5 (with *another* popped HG).... I "happen" to have a 90,000 mile 1990 EJ22 sitting in my garage. I've done a bit of searching and I've seen mention that it's do-able...but yeah - I'd like to maybe drop the EJ22 into the 99 and make it run again. What all is involved ? Anyone have a quick and dirty run-through ? Thanks, Dan
Starting this winter the wife's car (99 Forester) when starting in the morning would run like it had a fouled plug. After about a minute it would "clean out" and run fine. CEL has been on since then. I had "assumed" it was a bad O2 sensor(s). I ran my Torque app this morning and pulled these fault codes: B0303 - Body B0304 - Body C0000 - Chassis C0304 - Chassis C0340 - Chassis P0304 - Powertrain Cylinder 4 misfire detected P0404 - Powertrain EGR control circuit range/performance P0420 - Powertrain Catalyst system efficiency below threshold (bank 1) P0440 - Powertrain Evaporative emission control system P0483 - Powertrain Cooling fan rationality check P2043 - Powertrain Reductant temperature sensor circuit range/performance Also - upon further inspection it looks like the car only has (1) O2 sensor ? Or am I not looking in the right spot for the second one ? Any advice is welcome ! Thanks ! Dan
Hey All, 1999 Forester. I had a check engine light come on the other day so I stopped by my local FLAPS and had them bring out their reader. After many tries they finally gave up - their reader just would communicate through the OBD plug. I decided to try and pull the codes manually and when I got under my dash I found that the black diagnostic connectors were already connected. No idea how long I've been driving around like that...I've owner the car for about a year and I know *I* didn't connect them. So....2 questions. 1. Could this have been why their reader wouldn't connect to the ECU and 2. Would driving around with them connected for an extended period of time do any harm (to anything ) ? Thanks !
Just wondering if anyone else has had this problem or if it's just my luck.... Got the mizumo timing kit from the 'bay for my 1991 EJ22. stock pulley: with bolt: Mizumo pulley: with bolt: case is threaded all the way to the outside - there is no inside step to take up the "shoulder" of the bolt. Any ideas ? Thanks. Dan
Try here: http://www.shoptalkforums.com/viewforum.php?f=19 Here's a couple Fastbacks: http://www.thesamba.com/vw/forum/viewtopic.php?t=614476 http://www.thesamba.com/vw/forum/viewtopic.php?t=612042 http://www.shoptalkforums.com/viewtopic.php?f=19&t=142788 I myself own a 65 Notchback (with a 2300cc Type 4 motor) and I'm currently working on converting my street legal sandrail from a 1600 type1 motor to an EJ22 suby. Dan
