Sapper 157
8
Everything posted by Sapper 157
Okay gotchya. If i do the disk conversion, do i need to change the brake line as well? are there any other parts i need to change (besides new disks and pads obviously) Oh okay. im glad i asked then. Looks like ill just try the rear disk conversion method. That way i dont have to open up that rear knuckle
I'm possibly going to replace my rear wheel bearings in my 05 forester X. So far it looks like there are two options, tapered or ball bearings. From what I have read so far, it looks like subaru stopped producing the ball and now one can only get the tapered bearings. (my understanding is that they did this because tapered bearings take axial loads a lot better.) My question is, when looking on RockAuto, it appears you can get either the tapered or the ball, and it seems the ball bearing is a little longer in size. This apparent size difference will not affect the installation will it? I just want to make sure I get the right part. Also, not sure if it changes anything, but my subie has rear drum brakes and not rear disks. I assume the knuckle is the same but i am not sure. (also, before anyone asks, I am aware i will need a press and I do have access to one) Tapered Timken P/N 513248 Ball Timken P/N 511023
Hello all, My 2005 Forester XS gave up the ghost today. The slight knock that I used to hear only on hill climbs finally escalated to the point of throwing a rod. I work two jobs currently, so I dont really have the time to be screwing around with putting a new engine in it, nor do I have the money to pay someone to do it, so I am looking to sell it with the bad engine. What would be a reasonable price to ask for it as-is? It's a 2005 with a good working 4EAT, rebuilt title, nice interior, decent body, all maintenance records going back to when I first acquired the car (about 25,000mi ago), decent paint job (a few scratches here and there),and tires that are only about 7000 miles old. I live in the Spokane/Coeur d' Alene area. I am thinking $1,200 - $1,500 but that might be setting my hopes a little high. *Edit: Forgot to mention that the body has 154166 miles
I have an 05 forester with a 2.5 n/a as my daily. The car sees a 15 min hwy drive almost everyday on my drive to a from work. During that time I have a BlueDriver obd reader feeding live data to my phone. For the longest time, the car has stayed at a rock-solid 187 degrees during cruise at 60 mph. Yesterday I noticed that it climbed all the way to 210 before settling back down to 198. Coolant is full. When I got out to feel the rad hoses, upper one was hot while lower one was stone cold. I’m thinking I have a sticking thermostat, but wanted a second opinion. Am I freaking out over nothing?
So one of my tires decided to contract cancer... and the bulge has started to make the bead slip. The tread depth difference between my full size spare and the other tires is just over 0.100”. Can I run my spare for a little while without hurting the diffs if I put in the 2wd fuse? Just until I can get a used tire that has similar enough tread depth...
Looking for some new front brakes for my forester XS. The car is my daily but it does see occasional long drives where it will experience periods of braking on hills. Anyone have any experience with either of these brands from RA? I am just looking for quality brakes that won’t warp easily under average use/conditions, I don’t need anything fancy or track-rated. Power Stop: https://www.rockauto.com/en/moreinfo.php?pk=10181964&cc=1430723&jsn=11573 Durago: https://www.rockauto.com/en/moreinfo.php?pk=10701256&cc=1430723&jsn=11576
Hey all. Its been awhile. Got a 2005 Subaru Forester XS with the SOHC EJ25 N/A. Since around March, I've had a code P2097 off and on, and within the past month it has become a constant code. So far I have replaced the downstream O2 sensor (Denso replacement), the air filter, and the front A/F sensor was replaced with OEM only 11,000 miles ago so I am very hesitant to replace that one again. My short term fuel trim hangs around -2% to +3 on the highway, and long term trim stays around +4.7%. I have been told that those numbers are "normal" but please educate me if that is not true. My MPG is 23 - 24, and the car sees a mixture of city and short term hwy driving... so i believe that is a pretty average fuel econ. Is it possible my ECM needs to be reprogrammed? Other Information: Car idles smooth as silk at around 650 - 670 RPM Car starts great Engine response feels peppy (as peppy as a 4EAT can be) Car does burn some oil (quart every 1200 - 1500) Does not have any obvious fuel leaks at the injectors, fuel pressure regulator, etc. I do run some MMO thru it every other fill up The following was also replaced around 12,000 miles ago: Head gaskets (OEM) Spark plug wires (NGK) Spark plugs (NGK) I have not done any fuel pressure or cat back pressure tests, would those be good to do? Thank you all for any insight.
That torquing procedure was recommended for the EA81. And to my knowledge, it was not a retorque in the sense that they backed off the head nuts to zero torque and them torqued them. It was simply going over them again and making sure they were still at 57 ft lbs. I have done this before on my car but it has never moved the nuts at all. I wouldn’t recommend it for the newer cars, since there is a warning in the manuals not to go beyond the specified torque range or you risk snapping a head bolt. this procedure probably had little to do with the HG reliability of the EA81. It had more to do with the EA81’s 9 head fasteners, compared to EJ series 6 fasteners. (I think it’s 6 anyways... correct me if I’m wrong) Also, it had lower compression and was a smaller engine.
