Thank you so much for your in put..I found some info that had stated that it might be that only 00-04 would be compatible. the car does burn oil.. that is a concern. .. I was also reading about head gasket stop leak. it does not sound good. the mechanic is willing to put in a 60k engine for swap of my lovely 1970 honda 90 trail bike. I am woman who is willing to watch and learn.. but know zero or may not have been into this car for so much $, that I now feel the need to save my investment with a new motor.
My mechanic, that is willing to make the swap, had questions and so will ask them here:
1. Will 1995 Automatic transmission fit?
I understand from Johnceeggleston that it will not swap.. thank you so much for replying. John
2. Does the 1995 Bell Housing fit?
3. Does the Torque Converter swap to flywheel?
3. Would the motor mounts match.. could they be retrofitted?
4 What is the dif in the two engines and does it bolt up?
I am beginning to understand what this means in images of engines. My shadetree mechanic.. knows old model cars and motors and engines and welds and would like to find out if the 1995 could be retrofitted to my car. YES i understand how it would be the best and easiest and really work to use 00-04.. but for the sake of following through with my part of how to find an engine that will work in my car and to have done research, I will ask the questions. I understand how busy you all are.. life is like that.. and once again.. Thank you so much for any questions you can answer and most definitely for answering in the first place. Have a wonderful day. Jessie.
