scdrtramp
Everything posted by scdrtramp
  1. Hello, I have a '95 impreza hatchback and the speedo lites are out. I want to replace them all with LEDs, but am not sure of the bulb numbers are. there are large and small bulbs in the dash, but there are many bulbs that look the same, but have different numbers. what I need is the original equipment bulb numbers. I don't have the owners manual for it so I'm lost. If anyone can help me I would appreciate it. Thank's
  2. I have a '95 impreza. I got the adjusters freed up, but where should the level bubble be when they are right??, also there is a line gage on the other adjustment. it has lines to align, but can't find what lines should line up?? THX
  3. I have been trying to adjust my headlights too. I see your comments about parking on level spot. I'm wondering why theres no mention of the green levelers behind each headlight. Are they unusable or ???
  4. Thank you both. this is what I was wondering. I really appreciate the help. It seems that I have something in common with each of you. Imdew, I see you are a Moto-Guzzi fan, and I have owned a '78 V1000 convert for over 25 years. Don't ride it as much as I used to, but try to get out on the real good days. Miles Fox,, It seems we have the same last name.. small world huh. thanks again.
  5. Hello all, I'm new to the subaru world. I have a '95 Impreza wagon. When I bought it the guy told me the brakes needed bled. It does not have ABS, and has drums on the rear. I found where he had put a new wheel cylinder, and hard line on the left rear. I bled it with a vacuum pump bleeding machine, and found no air in it, and the fluid is clean. I bled it criss cross like they recommend, but it made no difference. The pedal goes almost to the floor and doesn't seem to pump up if you give it a stroke or two either.. I took it to a indy garage and he pressure bled them and found no air and it didn't help. I've noticed on ebay there are beefed up braces for the master cylinder that are for the sport models. My question is this,, could there be something wrong with the master cylinder mounting giving the pedal way too much play?? The car stops, but haven't tried it in a panic stop yet. We have snow now so I don't go very fast, but would like to fix this. Any help would be appreciated. THX
  6. Moved.....http://www.ultimatesubaru.org/forum/topic/150633-looking-for-95-impreza-rear-hubtrailing-arm-bits/
  7. Hello, I'm new to Subarus. I just bought a '95 impreza wagon/hatchback. I saw that a '97 is interference engine. Does that cover the '95 2.2?? thx didn't mean to jump on here. I'm just reading all I can.
