Costatus
Everything posted by Costatus
$175 Subaru GL = $175 problems
Costatus replied to Costatus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank you to everyone who quickly helped me out today I really apreciate it. This forum has been super helpful. Got the car running with another distributor from a junkyard 86 GL. I assume the ignition module was the problem but I couldn't figure out how to just replace it so swapped dist. And she runs great again !! ???????? -
Ok I'm in the shop right now working on this thing and still no luck. I did a little more research on the site and did another test. With test light on coil (-) I get the light on with Ignition on but when cranking I get no pulse the light just stays on. Some say this means bad ignition module or faulty wiring to IM. Is this correct? Also tested leads at the FPCU and got 12v with ig. On - black/white 12v with if. On but not when cranking - black/blue Black- ground was good Does that rule out my ignition switch? Also tryed coil (+) jumpered to 12v and crank but no spark or fuel. -
I checked the coil by doing a bench test with my ohm meter and it checked out according to specs I found on this forum. I made sure it had a good ground as well. I don't think the problem is the coil because I think the no 12v at the fuel pump is related to my no spark issue. There's no rust in the engine bay only rust is on the exterior body. As for the Fusable Links all I did to test them was do a continuity test so they may be bad like you had mentioned. -
Thanks for that info. I will replace the fusible links even tho I think the stock ones are good and I will replace the IM. I just wasn't sure about the IM because I'm not even getting 12v to the coil leads which is where the IM gets it's power from but I will try it anyways, thank you! -
Sorry let me clarify by "nothing" I mean the car won't start. Engine cranks and cranks no start. Battery terminals good Starter is fine the engine cranks Everything else on the car still works and has power all lights/ interior etc. I checked all 3 fusable links and they all had continuity through them. I will replace them anyways and try that. Are the ignitions on these cars problematic? I'll try and different ignition also. Thanks for the quick replies -
First time posting here, been lurking for awhile. I recently purchased a 1986 Subaru GL station wagon Carbureted EA82 5spd 4wd 218k. The car is a turd and has more rust and random colored body panels than numbers in it's VIN. But it was only $175! Car was running/driving daily and then I went to start it one morning like normal and nothing... -Things I've checked so far: Plugs/cap/rotor Coil Fuel pump/fuel filter Relays/condition of wires Fuses Vacuum lines -Things I've found out: No 12v to fuel pump at all but pump works fine when wired to 12v No spark at the plugs at all No 12v to either coil leads + or - No voltage coming out of coil main lead going to dist. Checked the screw on the dist. Rotor. Replaced relays and nothing changed Bench tested the coil to find 1ohm on primary winding and 9000 on secondary. Even replaced the " fuel pump control unit" aka FPCU or Revolution sensor. It's the small black box located in the drivers foot well near the hood latch area. I've come up with nothing after hrs of scouring through this forum on this issue except a few dead threads on the FPCU. Questions : Could the control/ignition module inside the dist. Be bad ? Although would this cause no power to fuel pump? I'm familar with subarus pretty well mostly ej engines but this ea82 should be simple enough is there something I'm missing that's obvious ? Any opinions or answers is greatly appreciated as I've been at it for 2 days and no luck at all. THANKS!!
