Everything posted by xdeadeye1
. "Some massive air bubbles came out too. I also pulled top hose for radiator side and dumped about a quart of coolant in that way. Finally after turning it on and off and burping it it finally seems to be normal. The gage stays where it used to (slightly below half) and am finally getting hot air thru the vents. It's not overhearing anymore and seems normal. I didn't even have to replace the thermostat and honestly I'm not going to until it goes bad. I don't wanna do that again lol. It seems that the incline and pulling the top hose did the trick. Who knew how big of a pain in the rump roast a subaru cooling system could be!" I knew!!! lol glad it all worked out for ya.
- 73 replies
- Water pump
- 95 Subaru Legacy
(and 2 more)
Tagged with:
In my opinion,, air bubble in cooling system,, that whole burping business is goofy. But its real. There are others here who are more mechanics than I am.. But same thing happened to me in the past, and it was due to air bubble . Keep filling it,, run it,, turn it off let it sit,, turn it on ,, fill it don't let it bubble over, shut it off,, let it sit a minute,, repeat. On the top passenger side of your radiator is a plastic plug screw. this is to help with letting air out and getting coolant into trhe block thru the top hose. Be patient.. it will work out eventually
- 73 replies
- Water pump
- 95 Subaru Legacy
(and 2 more)
Tagged with:
I used the felpro gasket, no sealant on my oil pump. You will hear 50 different things.
- 73 replies
- Water pump
- 95 Subaru Legacy
(and 2 more)
Tagged with:
mpg?
xdeadeye1 replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My 96 wagon gets 28 on the highway -
My woodruff key sheared also when my crank bolt worked loose. Below is the thread where I posted about it. page 1 shows the key way and how it looked.. Page 2 shows how I had to pull the crank pulley off , my crank was rusted . Lots of good info here: http://www.ultimatesubaru.org/forum/topic/149417-harmonic-balancer-quit-spinning/?hl= harmonic balancer
they also have the front cam and rear o ring set by beck arnley. Under camshaft seal.
- 73 replies
- Water pump
- 95 Subaru Legacy
(and 2 more)
Tagged with:
http://www.rockauto.com/catalog/moreinfo.php?pk=128253&cc=1269806 rock auto dot com subaru legacy 2.2 engine crankshaft seal 5th one down the above are the order of links to get to the crank/ oil pump felpro gasket set,, $5.12
- 73 replies
- Water pump
- 95 Subaru Legacy
(and 2 more)
Tagged with:
rockauto.com they have what u need. I just did my timing belt. I have 180k on the car. I took apart the oil pump and replaced the o ring and gaskets.. guess what. 3 of the screws inside the pump were backing out . A good ways out. Im glad I took it apart and found them before it failed. I got a felpro kit from rockauto for around 9 dollars.
- 73 replies
- 1
- Water pump
- 95 Subaru Legacy
(and 2 more)
Tagged with:
So today I went to the local Junkyard. I found they have a 98 outback wagon. I have the 96 non outback version. The seat in it is 5 x better than mine is,, it was oozing support and plush lol They want 35 so I told them I would be back Monday to get it. Anyone think it will be a problem being too high or anything? It does have this extra manual seat height adjustment on the side of the seat. My 96 doesn't have that.
