Everything posted by xdeadeye1
I replaced my emergency brake shoes in the rear, along with all the hardware, but I still don't have e brake, the cable is adjusted all the way out at the handle. I guess my cables are stretched. There is one short cable from the handle, that quickly changes to 2 cables. Any fix for this? Or is this a full on cable replacement?
Saw an ad for a 2001 forester with an issue. I don't know if this is a common thing. Hard fix? it says it's automatic, drive train is all good. Driver side Rear strut tower is bad. Rear tire is leaning. Is this common? Is there a kit? I'm guessing it's rusted bad. Salt on roads. Any help is appreciated. Yes I know you could tell me more with a picture, I haven't seen it first hand myself yet. I'm just gauging whether its worth it. 133k miles, Asking $700
well it was doing this noise/ feel,, while I was on the gas.. then I let off and it doesn't do it. concrete spacers ,, I mean when you go over a concrete road that has expansion joints, you can feel them / hear it. its a small thump and its not consistent. I can go miles and it doesn't happen. Most of the time its when I accelerate,, and moreso when on an uphill grade. "I don't have a slow down or deceleration" meaning when it happens the car doesn't slow down. or speed up. I don't hear a transmission spinning with no movement. Its just a "wump" in the rear of the car that feels like someone took a fist and banged on my rear quarter.
Hi guys. 96 legacy wagon 2.2 automatic. Recently noticed what sounds like a noise from the rear end or the drive shaft. Accelerating,, going up an incline usually,, but not always. I hear/feel what feels like going over concrete spacers,... a fump... if you will sometimes in succession. / not like a machine gun,, spaced out feels like something slips and then catches.. I don't have a slow down or deceleration,, and I'm 90 % sure its not a tranny slipping. Idk what it is. to me it feels like its coming from the rear.
i mi messaged the guy and told him i was quite a ways away but would like to see the car. I asked if he would get the codes at auto zone and let me know what they are, before i drove down there.. (its 6 hrs away) He said " thats why its cheap, not messing with it no more" idk for 1350 or a lil less,, the car is probably worth it right? I dont have inspections here so if light is on no biggie.
I spoke with the seller. He said there is a CEL on . He said he cant get it inspected with that light on. He hasnt been able to clear it. He didnt tell me the p code, he said it was a fuel temperature code. After reading a bit i found some others who had this code, but im not sure what exactly it entails. The Seller said he replaced the fuel pump (i believe this is where the fuel temp sensor resides). But it didnt clear the code. This could be a cause of the poor running at start up, but im thinking its probably a combination of that and the coolant temp sensor. After reading around these forums i thought maybe the computer was replaced and it didnt have the same computer as the original. (thus causing this fuel temp sensor problem. I asked if the engine was ever out of the car, he said he didnt know. Anyway its a nice rust free vehicle. I was thinking of getting it. 150k miles on it. Im listening to your advice.
i found this diagram online, if im reading it right there is no plug near the hinges.. i would have to unplug all connectors and then fish it up through the hole in the top,, then fish them back down inside the new lift gate. if im reading this correctly http://parts.subaru.com/a/Subaru_1996_Legacy22L-AT-4WDBase-Wagon/_52016_6023053/CORD-REAR/B11-815-02.html
I saw the ribbed rubber shroud, I pulled each end of the rubber thing off,, but didn't see a plug. I didn't PULL on the wires. I just wasn't sure if it was up in there,, at the top..,, or if there was a plug somewhere else like down at the tail lights that I would then have to pull up through the rear posts. It would make sense to put a plug at the top at the rubber shroud,, I just didn't see any.
Hi guys, 1996 legacy wagon 2.2 EAT I have a parts car and I want to swap the lift gates. The hinges etc seem self explanatory. My question is on the electrical system. I need to disconnect the wiring from the body to the lift gate. Is there a plug somewhere that I can get to and just disconnect the plug and remove it and then plug it into my regular ride?
