10
Everything posted by sirtokesalot
thats the issue im having. i dont know what size they are most of them are fixed to bases and are supposed to be replaced with the base. im ok with having to in trwist the leads off the bases and put new bulbs on the original bases just dont know what bulbs to use. some of these things are tiny like smaller than a piece of rice some are the same size as a piece of rice and soime are about twice as big ad the rice.
many different bulbs throughout. are there any led options for the dash bulbs? climate control heated seat switches the tiny ones in the dash switches and window switch. ive changed them all as of now with other bulbs from part cars but most of the replacements did not have the green condom over the bulbs like the old ones did and now i have a mix of green and white illumination would like to replace them all with led's in the factory green color.
i believe i know the issue but not sure if i can fix it. the replacement transmission came from a legacy. the legacy used 205 55 r16 and the outback uses 215 60 r16. how does the car know what the speed is from the transmission is it as simple as swapping the speed sensor from the old transmission or is it some small gear inside the transmission?
well this is what has happened. i managed to get everytihng installed and the security does work the dome light never seemed to change operation though. i tried for a while to find a way to make the aftermarket remote start fob i have disable the factory security and finally decided its not possible so i removed the security module seeing as it did not seem to change the dome light option. im thinking i may pull the factory keyless module from the old car and use it to make the dome light function like i want it to. it just seems wrong to me as it is now. the current keyless module int he car makes the dome light come on and delay about 4 seconds before just turning off. it will not come on when i shut the car off ither. the old model keyless unit would leave the light on for like 15 seconds or until the car started. and the light would come on when the car was shut off and i dont think the new model module will do that from what ive seen now through 3 different keyless modules and security modules.
i will check those out next chance i get. it has started snowing here and wasent planning to go out anywhere today the part car is about 45 min from here but im assuming should be easy to find the relay as the dashboard is out of the part car so should give me an idea where to look in mine when i find it in the part car. the b93 is that not the security unit its self? b243 kinds looks like it would be behind the fuse box area but i wont be able to check on that till likely wensday witch is the next time i plan to head up to my friends house with the part car. any other info before i get out there would be nice but ill take it as it comes i dont want to push u on finding it i know it can take a while to search through it all. would the security horn work without the b243 relay? the horn did honk when i set off the alarm. just wondering if maby its already there because the horn did honk.
from what i can tell the security module is in valet mode currently 2 rapid flashes every few seconds. i kinda want to leave it there because i have a remote start installed with its own lock/unlock buttons as well and did not intend to use the actual alarm more just want the delay function. i mean i could probly use the alarm but id have to figure out what to wire in from the remote start to bypass the security but it would be easier to just leave it in valet mode. the security light does the rapid double flash every few seconds with engine off and it stops blinking while running. i might mess with it tomarrow but its too late to be having horn honks and lights flashing outside right now
hmmm i was looking for that module as well as it was one of the ones i was suspecting had to do with it. i couldn't even find the plug for it. would it be visable with the dash board in place? also if its not there would u know what relays and fuses would have to be put in? i will be hunting for it again.
there was another module there but i dont remember what it was. so the security module has to move over as well? i dont think my car has the security on it. it was a base model that has been upgraded with almost every feature offered at this point. is there any other modules it ties into? i can swap those next itme im at my friends where the part car is
ive noticed that my older 1998 outback and my friends 2002 outback have a delay feature in the dome lights where after getting in and closing the door the light stays on a few seconds then fades out or after shutting the car off the light will come on and stay on after u get out and close the doors for about 10 seconds. what module makes this happen? my 2001 outback does not do this the lights only come on if the door is open or if i use the switch. once i shut the door its off immediately no fading out no delay.
well heres my verdict. the engine rebuild did help it i no longer hear the rattly sound while accelerating but the knock still exists when cold. at this point i accept that the knocking im hearing now is piston slap as it quiets down now within a minute of running even at idle and is smooth and quiet after that so rebuilding it did help alot but still have bad pistons in it causing a slap when cold. i do believe there was something els going on besides the piston slap due to the rattling sound going away after the rebuild. i am happy with it now and at least have the peace of mind knowing there's nothing serious wrong in the engine at this point.
well today we put the engine back together with standard sized bearings. i used the engine that was in the car. we tore it down sunday and it was in very good shape no visible wear everything we could measure was within spec not sure what was knocking we suspect it was from a lack of oil due to a partially clogged oil passage in the crank for cylinder 1. the rod bearings were lightly worn but i dont think should have caused the knock. i reused the pistons if it still knocks now its piston slap. i wont know for sure until wensday when the head gasket set arrives unless it arrives early. engine has new rod and crank bearings new piston rings and every seal on the block has been replaced. it should be basically a new engine. i might pull it again and pit pistons in it if it still does it but for now i want the car back before snow and ice comes and it should run fine and id feel better with it knowing everything inside is new.
so the stock sizes wont be correct then? the rods have no scoring and the crank has no scoring the rod bearings seemed to be the only worn part on the crank. why would the pistons need to be knurled? i would be using the pistons that came out of the engine and what do u mean with the rings? im sorry i just dont understand it. i am mechanically inclined but this would be the first engine ive torn this far down and done rod bearings on. i have changed rings before but on smaller engines and i just ordered the ones that were for it. so far i havent ordered anything yet for the forester block. i tried a valve adjustment today on the engine in the car now and it did not change anything. my mechanics stethoscope showed up today as well and i can say the sound is definitely coming from the block and i can hear a distinct metal on metal knocking sound from the block very faintly still but its in there.
Well that forester engine turned to hell. I tore it down and got the pistons out to find rod play in all of them. Not alot but still there. We split the case and pulled all 4 rod bearings they were pretty much toast but the crank is good and measures in spec and the rods measure in spec. So if I keep going this route it's new rod bearings new rings and new head gaskets as well as all the small o rings and crap to reassemble the case.i will also not use any other part of it besides the block. The heads were full of sludge the oil pump sludge oil pan sludge starting to wonder if I should bother with this block or not. I mean the clock looks good and is in spec but where els could sludge be that I cant clean out? This is not the engine that was in my car. This is another engine I had sitting around from a 2001 forester I parted and scrapped. I might just spend the time and redo this block. At least I'd know it would be like new inside when I finished and shouldn't have to worry about engine issues again for a long time.
this engine does kind of have a hidden history i left out. the car belonged to my mom before me. 2 years ago the head gaskets let go and it mixed coolant in the oil started to overheat then got towed to my moms house where they then moved it 2 or 3 times in the yard never drained the oil/coolant mix and it sat for nearly a year before they towed it down to me to change the head gaskets last year. the cars done about 7000 miles since then and the knock has been slowly presenting its self. i think this is the reason behind it all. i have a possible plan c as well now too. i have the forester block with low compression but on top of that i have a friend whos looking to replace his wrecked subaru .... he still drives it but its technically totaled anyways hes going to look at a rust free car today that needs a transmission and i told him if he buys it ill do the work of swapping the transmission from his old car and whatever engine he wants to keep ill make be in the new car but i want the extra engine for payment so that might work out for me but i wont know till later if he went and got the car or not. im likely going to go out to my friends house later after work and pull the heads off that forester block i have to check the internals and see if its a worthy swap. the forester block is low compression but did run without knocking last time it was in a car it just ran poorly.
