sirtokesalot
    10
Everything posted by sirtokesalot
  1. hello i need ideas what to check please i am late for work allready called them as i was pulling out of the driveway my 1998 outback ej22 stumbled and stalled rolled back into the driveway and is now a crank no start what can i check to try and fix this? does the 98's have the fuel pump issues like the newer 2000 cars?
  2. i have a theory why that code comes on so many cars but not on others. the cats on my car had the o2 sensors setup one before the cat and one in between the 2 cats none at the end. when i replaced mine i used the cats from my 95 witch had abotut he same miles on them but did not give a 420 code the o2 sensors on the 95 cats are in front of the first cat and behind the second cat. so my theory here is what if u got an o2 sensor bung and had it welded on behind the second cat plug the one in the center and move the o2 sensor behind the second cat would possibly correct the issue?
  3. ive seen the hose clamps on the filter leak from being loose on 3 different outbacks so far id check there.
  4. ooo yes i missed it was a just legacy and not outback. im not sure if they will fit that car.
  5. i have a 1998 outback and can tell you that 205 55 r16 fit on mine great and do not rub anything speedo shows faster than really going though but not off much 215 60r16 also fit but very close and on mine they will rub on the mud flaps speedo way off using that tire.
  6. nope. ive done the lower ball joints and inner/outer tie rods rotors brakes ive come to the thoght that maby its play in the steering rack it does have slight up down movement in it. i have another rack but haven't put it in yet been lazy with it and just driving it like that.
  7. thank you. i got the car today drove it to friends house running on 3 cylinders or maby 2 and a half i dont know just know it ran like crap. trans shifted great thogh and went into all gears so its def getting pulled for my moms outback. im also planning to pull the calipers off for spares on my car as well as the axles starter alternator and most likely save the diff as well the rest will be going to scrap. if the junk yard will take it without wheels and suspension i might take the shocks and springs too for a lift on my 1998 outback.
  8. will the transmission from a 2001 forester work in a 2001 outback? im picking up a free parts car today mainly for the transmission. it runs but on 3 cylenders and its kinda beat up cars not worth repairing.
  9. is it a manual? not sure if the 95-99 radiator would work but i have one was ment for an auto but the trans cooler fittings leak radiator holds coolant would be great for a manual 20 bucks its a newer radiator boght from junk yard car because it appeared to have been replaced recently then found the trans cooler leaked trans fluid externally from the fittings and couldent get it to stop.
  10. i thought 95-98 was same am i wrong? i have a 95 engine and trans in my 98 outback.
  11. does anyone know of a good video showing how to remove the lifter? i have a spare head for parts that did not tick before the timing pulley seized snapping the camshaft off in it.
  12. I can say no ticking after it sat 4 hours until my lunch break seems to be intermittent after its sat overnight it sounds alot like a valve tick next time I hear it I'm going to try to get a video.
  13. I noticed the other day a tick when I started the engine that went away within a few seconds and today that same tick was back and I did not notice it right away I had driven about a half mile before I noticed it.sounds like a valve tick once I noticed it I free revved the engine once in neutral and the tick went away and was silent normal running from there to work. Should I be worried about it? Is there anything I could do about it? This is on a 1998 outback with the 1995 2.2 engine
  14. ditch the k&n it doesn't filter as good as a quality paper filter and ive seen them cause issues from the oil in the filter getting on the maf and causing running issues. ive also seen a nice dusting of dirt inside the throttle body after using k&n filters for long periods of time.
  15. ive had the cogged pulley seize on my 2.2 engine causing the belt to yank the cam so hard it snapped off and had to replace the head and belt/pulleys my friends 2.5 had the bearing completely disintegrate on the smooth idler causing it to jump out of time and make a serious racket but did not damage valves and he was able to just replace the pulleys and belt.
  16. well when i would post it on Craigslist it will have a new used transmission in it and would drive fine again im basically trying to figure out what i should ask for it with everything working and all the recent work done.
  17. rear subframe was in good shape the transmission is done its making a loud clunking sound when it is in gear moving and gets faster with more speed. they thought it was an axle or u-joint but it got alot worst very fast and the shop they brought it to said it was coming from inside the transmission. i cant check it personelly as my mom brought the car back to vermont and it would need to be trailered back here for me to put a transmission in it. my plan here was to get the car here grab the transmission from my friends blown up 2001 3 cylinder forester and drop it into this outback. i can get the transmission for basically free id have to change a few parts on his car in exchange for it.
  18. i did the head gaskets and yes the heads were machined flat. i did not want a failure on moms car. unfortunately i did not see the transmission failure coming it drove great for the 3 weeks i drove it after the head gaskets before i gave it back to her. i had also repaired all other issues it had while i had the car including replacing missing trim parts from the interior. when i got the car she said to do the head gaskets witch i did then proceeded to clean the car fix the burnt out dash bulbs find and replace missing rear headrests found a rear hatch panel installed newer subaru radio and tweeters swapped plastic window switch trim for wood had fuel pump failure and put new used pump from one of there parts cars wet sanded and polished both headlights replaced upper coolant hose new timing belt and water pump no check engine light came on in the time before trans failure and all emissions monitors were ready when i gave the car back to her.
  19. i currently do not have pictures of the car but i can do my best to describe it. it is a 2001 outback has the wood trim interior is clean complete all working exterior is ok has some scratches and dings poor rust repair in the rear but solid 180,000 miles new head gaskets last month my mom wants nothing more to do with it and is tired of putting money into it the transmission failed. i want to buy it from her for the 500 she wants and put a trans in it then sell it what should i ask for if i do this? i was thinking it could be worth around 1800 in its current shape with everything mechanically and electrically working with new head gaskets am i right on this price?
  20. sounds like water pump or t-stat housing. closely inspect the area i suspect you should be able to see a wet spot where its coming from. it could even be a loose hose clamp on the lower hose.
  21. if i need a jack in the yard i just rummage throgh other cars until i find a jack in the trunk somewhere.
  22. dont use armor all unless u plan to use it religiously. if you use it then stop using it armor all will cause it to crack faster.
