10
Everything posted by sirtokesalot
he bought one from the dealer. reason for replacement was he drove it without a wheel bearing for god knows how long. replaced the shock hub bearing axle caliper caliper bracket abs sensor and tone ring parking brake hardware still need a new parking brake cable he may not buy it. thankfully we used a junk yard part so most of this stuff was already assembled.
i have added lucas into my rear diff trying to get rid of a whine. actually it was a lucas a limited slip additive and good quality gear oil about 65% gear oil 35% lucas. at first it did not help much but as i drove it the whine did get quieter it was a loud whine originally and the mixture of fluids had quieted it by more than half of what it was. not sure if it would help at this point but maby someone els will see this and get use from it.
does anyone in connecticut have one of the long bolts and nut that aren't destroyed? im speaking of the long like 12 inch bolt that goes through the 2 lower control arms on the rear. it is for a 2002 forester but im pretty sure the same bolt for other models will work. im so close to getting the car back on the road but am being held back by one dam bolt.
98 outback
sirtokesalot replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
im pretty sure if you unhook the battery turn the key on then hook the battery back up that will trick the alarm off. it is part of the keyless unit. -
well im loking at ecm,s on ebay because no local pick n pull yards have any subarus in their lots. im reading alot of information saying ecu's have to be reflashed before use is this true considering the ecu i am buying is the same part number as the one i have will it not just work when i plug it in?
yet more updates. i had some help today and learned the switched side of the relays powers are all good i can bypass every relay and get the fans to come on. i also learned the relay in the drivers foot ares is the main fans relay if i jumper this relay through i get my main fan to come on and it also makes the missing power i had in the engine compartment relay be there. i believe my issue lies before the main fan relay inside the car witch im assuming is going right from that relay over to the ecu. how likely is it the ecu could be bad? anyone from the ct area willing to allow me to try their ecu?
i have it in my cars as well but i used the aftermarket version of it its not built into my radio. i would guess the antenna placement is not as good as with your other vehicle. i have also noticed i get better reception with it during the winter months when the trees have no leaves on them when summer comes back around and the trees start growing back their leaves i start losing reception in areas because of the dam trees being in the way.
did some more checks i jumped power into the fan and the fan does spin up. i have been looking at it backwards its the a/c fan that is running and the main fan is not coming on. i found another relay for the main fan above the under dash fuse box and swapped it with its known working friend the rear defroster and still have no main fan running. im pretty sure the relays are all good as they will all turn on the a/c fan. what is the chances the ecu could be bad? the wiring diagram i have shows there controlled by the ecm. im fairly capable of electrical work but not so great at diagnosing it.
ok i have rpaired the ground wire for the dirvers side fan and the power wire for ither low or high speed not sure witch on the passenger side fan. now if i plug in the green connectors under the dash i have the drivers side fan running not sure if its cycling between low and high but it cycles on and off the passenger side a/c fan still wont run even if i turn the a/c on. when the a/c is on and the compressor cycles on the drivers fan spins briefly but does not keep spinning only when the compressor cycles on. im sure if i let the engine warm up it would probly come on. what should i be looking into about the passenger side fan not working?
ahhh yes dam i always forget to do that. its a 98 outback. and as i stated in my post i used the green connectors under the dash to test and see if the fans were working witch is how i learned they were not working. so the relay for the fan is in the fuse box under the hood witch means its probly not the relay as i swapped all those relays around trying to get the fans running in new jersey.
i went to six flags new jersey yesterday it was fun no issues driving there. about 30 min after leaving there thogh the car began overheating. it never got to the h but overheating none the less. pulled over and figured it was low on coolant nope coolants full. thought it was because i was running the a/c shut a/c off started driving again it starts overheating again. second time pulling over now i decide to plug in the green connector under the dash to find out if the cooling fans are running and i have no cooling fans both fans would not run low or high speed. i found the fuse for the cooling fans but it was good tried swapping it with one of the other fuses in the box no change. i dont know where the relay is for the cooling fans so i did not try swapping a relay unless its one of the ones in the engine fuse box i swapped all those relays around. in the end i wound up using a piece of the speaker wire from my subwoofer setup to run a constant power from the battery directly into the fan so the fan would run high speed for the 130 mile trip witch got me home. so now its home and i dont know why the fans wont ruin is there any common issues for this?
