10
Everything posted by sirtokesalot
this is my second winter with the car. i changed the trans fluid during last winter did not drive the car much through the summer. ive put a new coil on it new wires new plugs. the transmission fluid is still bright red colored no burnt smell still right at the full mark. when i changed the fluid i drained what was in there refilled it drove it about 20 min and changed it again. ive done alot of other work on the car but none that i can think of that would effect transmission. such as replaced oil pan repaired trans cooler line brakes and such.
ive plugged tires in the past and had them last for years and ive also plugged tires and had them go out again a month or 2 later. my favorite plug job was on my own tire i plugged the side wall i know i shouldent have but the tire was near new tread wise and i was broke. that tire went on 3 years before the plug blew out and i was forced to get another tire but at that time the tire was well worn and needed replacing.
i have a 95 legacy auto. the trans has been shifting a bit weird to me. it likes to hang out of first gear until around 3500 to 4000 rpm even if im light on the throttle. and when it shifts from first to second its not as smooth as i think it should be. it also seems like it takes it a second to actually fully engage the next gear this issue happens with all gear shifts. does the trans-x stuff work with the older transmissions?
i will make a harness for it all with bigger wires i was just curious what it took to get it done because once i do get the projectors it will have hid's and only one bulb for both high and low so they will need to be that way soon just getting things started. the halogen bulbs should last that way for way longer than i need them too.
today i traced the wire's from the alternator and found they ended at the fuse box. can i safely add a second wire from the alternator to the battery? reason for this is because i have a stereo in the car big amp and it wants more juice and i think im losing some power through those small wires leading to the fuse box first then to the battery.
i am trying to figure out how to make the low beams stay on with the high beams. im not worried about bulb life and such ive done this mod to my other cars and haven't noticed any difference in bulb life. the bmw i had to open the fuse box and cut a ground wire off the low beam relay and wire it to a constant ground point instead of the switched ground point is there a simalar type thing that has to be done on the subaru? i have a 95 legacy wagon with the 2.2 motor.
i was curious if anyone here was from ct has a welder and would be willing to help me fix some holes in my car. i don't need anything pretty just want the holes covered up so the car wont fall apart. i have holes up around the rear strut towers i will remove the suspension stuff so you can weld in there but i do not know how to weld never tried nor know anyone with one.
possibly piston slap? a friend of mines subaru has this and lucas made it louder.
- 18 replies
- light tick at idle only
- common?
(and 2 more)
Tagged with:
well the trans cooler lines rusted throgh on my 95 legacy im currently trying to sorce a new set somewhere but i have a question about them. what is involved in replacing them? it looks like i might gave to remove the rear cross member and lower the rear of the trans to get to the bolt for the line . can it be done without lowering the trans? does anyone have any good tricks for this job?
