sirtokesalot
    10
Everything posted by sirtokesalot
  1. junk yards around here give around 250 for a full car driven into the yard a friend of mine recently scrapped his car due to rust the rear wheel was about to fall off and front sub frame was almost non excistant i was surprised it made it to the junk yard without falling apart on the trip. anyways scrap is down they aren't giving much for cars that's how i got my 95 for 300 scrap yard was gonna give them 250 i gave them 300 and drove it away. im not saying scrap it now but im sure you could get more than 300 for it any day of the week. i had to do quite a few things to my 300 dollar subaru to get it road worthy again.
  2. id just take the center console apart and remove the shift lock so it can shift without holding the brakes.
  3. i dont like changing headlights in pairs because when one fails the other is gonna go soon. if u replace both of them than the chance comes up that one will die and the next night the other one will go out too this has happened to me before i did not have time to get a new bulb before the other one failed so i like to change them one at a time because then i know when the other one does fail that one i replaced will keep going long enough for me to change the bulb
  4. my exhaust is all patched up the same flange broke on mine repaired the same way i had 2 holes form in the piping about 3 feet from each other there's sheet metal hose clamped over those the muffler broke off flush i bought an adapter that was tight fitting to the inside of the mufflers inlet hole hammered it in and clamped the muffler back on to the piping. in the front the resonator broke free i have some strategically placed hose clamps holding that together and its actually pretty quiet you wouldn't think it was broken and repaired in so many places from the way it sounds.
  5. we found the issue the gate was being pushed on the left side too much. we had the interior out of the back of it today and massaged the rear end a bit more got it a little straighter. from here his plan is to fiberglass over all the dents there and put some body filler over that. if the corner comes out good enough hes gonna replace the tail gate.
  6. my friend got rear ended and i helped him pull the mashed in corner back out the other day there was about an inch and a half gap along the drivers side where the gate did not seal before we started. we managed to bend it back far enough to get a new tail light in it and the gate to close and seal up but the interior light does not shut off all the time sometimes it will sometimes it wont it needs to be slammed shut hard to get the light to turn off. where is the tail gate door switch located? we couldn't find it. we pulled at least 6 to 8 inches of car back out from that corner it was really stuffed in there.
  7. i decided to just wait for it to go to my brothers shop he has a hoist and all the right tools.
  8. it has the ej25 engine. i like to consider myself a bit of an advanced mechanic ive always done all the work to my own cars. we do have a service manual for the car i was hoping it could be done with the engine in the car as i do not have an engine hoist. its in my driveway now and my mom has my legacy for now. my brother cant get it into his shop for 2 weeks so i was looking into what needed to be done to see if i could maby get it done sooner.
  9. my moms head gasket went in her 01 outback wagon. whats involved in doing the head gaskets on her car? how much stuff has to come apart? does anyone know of a good write up?
  10. that theory is gone i took it out today and tried to smack the dash a few times witch dident work then it just jumped up im gong to say its probly the speed sensor
  11. so i drove the subaru the other day and the speedo did not work. the check engine light came of with a p500 vehicle speed sensor however if i smack the top of the dash the speedo turns on and works fine until i stop the car for a period of time. will the car throgh a p500 with a working speed sensor if the speedo does not move? could this be a loose connection somewhere? 95 legacy wagon
  12. im unsure of part numbers they were on my friends outback and he got new rotors i know his old rotors were only a year old and are in much better shape than mine. maby i should just grab them and see if they fit
  13. i have a chance to get 2 rear rotors from a 03 or 04 outback wagon for free. would they fit on my 95 legacy? i need rear rotors bad.
  14. if you crawl under there and smack the cat with your hand can you hear stuff inside rattling freely? if so the cat has broken apart internally and will need new one.
  15. i have my plates bolted on with through bolts using all 4 bolt holes. no one can steal my plate because unless you hold the nut on the back side its not coming off.
  16. every time i go to the yard i look in every subaru of proper year for them. so far i have all but the ones for around the radio and vents. i found the one for around the radio once but someone ripped it out and broke it.
  17. im helping a friend find a car this afternoon. the car i found is a 1995 subaru legacy sedan. aside from checking for rust in obvious places what should i look at with this model subaru? http://newhaven.craigslist.org/cto/4967330790.html
  18. you could build your own refrigerant recovery system/ vacuum machine.
  19. ive decided to just drive it once every few weeks to keep things moving. im only paying 63 bucks a month insurance for both cars. its strange going form one car tot he other. the subaru has a tight feal but poor ride quality while the bmw is loose feeling but has a nice ride. its a 27 year old car the bmw ive owned it for 11 years.
  20. my 80's bmw has some simple security system that is controlled by the on board computer. i had disabled it but it worked by disabling the spark. if i entered a code into the computer the alarm would activate and if someone tried to steal it the car would still crank but the 3rd time the horn would beep. im sure it wouldn't be to hard to hook up some kind of spark kill switch.
  21. the all metal rad in the bmw lasted 28 years and if i dident accidentally mess up the upper hose connection on ot that radiator would still be fine. i also dont like the plastic tanks.
  22. 95 legacy wagon 2.2 4eat i averaged about 21 mpg. i dont drive the highway much so this is an average of all driving.
  23. the bmw has already gone too far with the rust for repair in my eyes however the rust is all for the most part hidden and the car drives very well so i want to keep it for as long as it will go before the rust gets too bad to keep driving it. the subaru has rust too but i think it is saveable if i get into it before next winter. the bmw was in very good shape when i bought it but it was my only car for a long time about 10 years of all season driving with it and the salt already took its toll on the car im just hoping that by not driving it through the winters it will last a few more summers.
