10
Everything posted by sirtokesalot
clean the sensors check the tone rings. my plan was to just use a hack saw at the yard to cut it off the car there the plan was to cut inside the valleys. if need be i could probly have someone weld it back together once its on the car but it sounds like i wont need to do this and it should just work fine.
so the tone ring on my car is rusted away on the fr side. will the abs system notice if there is 2 cuts in the tone ring the cuts would be in the lower parts of the grooves. i understand that i cant remove the ring without removing the hub so i was tihnking that maby i could cut a ring off from a junk yard car one cut on each side then remove the bolts holding it there do the same for the one on my car then bolt the 2 halfs of the new one on. would the sensor notice the 2 cuts?
i normally don't warm the car i have a habit of just getting in and going i cant afford to let the car run for 10 or 15 min to warm up that's a few miles i could have driven. i don't drive the highway often i tend to stay on back roads with speed limits of 50 usually everyone is doing 55 the rest of my driving is at around 30 to 40 mph driving to work and home with 6 stop lights on the way. i have new plugs and coil still using the wires that were on the car no vacuum leaks found. it has the auto transmission and 194,198 miles currently.
ok well i cleaned the oil out of there and put the plug back cars running now warming up. it missed for a moment when i first started it but im guessing that was from the little bit of oil that got in the cylinder because it cleared right up. once it warms up im going to take it for a drive to see if the problem is fixed and if it is than i need to figure out how the oil is getting in there.
they are ngk platinum alloy plugs its what the parts store gave me for the car. the wires are the wires that were on the car when i bought it. the coil is a diamond coil that came from a junk yard car witch looked like it has the coil and wires replaced recently i should have grabbed the wires too. its been cold outside i haven't gone back out to the car since last night its still 9 degrees outside now. when i replaced the coil last time there was oil in the #1 spark plug hole could this oil be what is causing my misfire? it looked like it was running down the top of the block and into cylinder 1's spark plug hole. the oil was not pooled very high in the hole but it was there i cleaned it out when i changed the coil it could have pooled back in there again in this time now.
my 1995 legacy wagon has begun to misfire again this time it happens after the car has warmed up once its warm it starts missing when idling and will misfire while driving until i get some speed up then will stop missing until i slow down again or drive to easy for too long. i keep a code reader in the car 2 times today the check engine light began flashing and as soon as it would stop flashing and go solid i would scan it and get p0301 each time cylinder 1 misfire. i have new plugs on the car and i replaced the coil recently with another used coil. what do you think my issue is? witch cylinder is # 1?
this sound slike what happened to my mom with her 03 outback check this video out at the 9 minute 43 second mark. the metal cap he unscrews was not seated on my moms pump causing this issue for her after reseating the cap the car ran. it could also be the o-ring. https://www.youtube.com/watch?v=oXH1A9sHt6M
the picture doesent really show it but i did clean the areas where i applied the jb weld. as a side note i do have por15 left over from when i repaired a gas tank on my 87 bmw im gonna take it it would be a wise decision to coat the bottom of the oil pan with it? unfortunately i do not have a garage though and por-15 cant be applied at below 45 degrees and its below freezing here now so the jbweld is gonna have to work for now. if it holds up ill por15 it later. im not going to put oil in it until later i figure the more time it has before oil is flowing behind it the better
it started as one leak i intended to patch right next to where the dipstick enters the pan but during cleaning off the oil some rust flaked off and opened up another leak a few inches away the oil pan is rather rusty but i cannot afford a replacement pan at this time. the leaks were what looked like 2 small cracks and one small hole about the size of a pinhole but slightly larger than a pinhole. all the leaks were above or level with the spot the dipstick tube enters the pan. here is the patch work. the left patch was a small crack and the right pathc was the small hole and crack near each other i spread it over that area wide.
