Husky
Gender
Not Telling
Location
Davis, CA
Referral
Google
Vehicles
'99 Subaru Legacy Outback
Husky's Achievements
Member (2/11)
0
'99 OBW ABS Light
Husky replied to Husky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Where was the ground that you cleaned up, if I might ask? -
Hi all, So the ABS light recently came on in my '99 OBW. I placed the ground pin into the diagnostic connector in order to get the DTCs and ended up with codes 56, 42, and 11 (The start code on the sequence) I understand code 56 to be for an 'abnormal G sensor output voltage' and code 42 to be 'source voltage is abnormal.' My question is, what's the best way to verify these codes? The car has around 175k miles so I wouldn't be surprised if a sensor went bad, but I'd like to check in order to make sure before ordering any parts. Is there a test I can do with a multimeter on the G sensor? If so, what is the location if the G sensor in my car? Also- is code 42 related to the G sensor as well, or is that a separate problem? Thanks!
Hi all, I have a 1999 OBW 5MT with ~175k on it, and I've noticed that it's running a little rough. It's definitely not too bad, and is quite livable, but I'm wondering if there might some cheap fix. The issues I've noticed, and I'm not sure they're even related, are that the idle is a bit rough when the engine's warm, and that the entire car jerks a bit if I come off the throttle too quickly. It also usually takes more cranking than I think a healthy car should to start. I'm pretty sure the issue isn't electrical, as I recently changed the spark plugs with ones recommended by my mechanic (I believe they were NGK irridiums.) I also changed the plug wires when I did this, as one had a torn boot. The battery is healthy as well, as tested with a multimeter. Anyone have any thoughts on this? I would think maybe to start by trying to clean the idle air control valve? Thanks
This might sound weird, but I'm quite happy right now, so.. Thank you. You are all beautiful people. ...The problem was *indeed* with the solenoid wire.. it wasn't attached. Funny thing is that I don't even remember taking that off when I removed the starter, so it was easy to miss putting it back on. Thank you again, my Subie is starting and running wonderfully now (and without any of the rumblies it had from before the center diff rebuild!)
imdew, when you say the small wire on the back of the starter, do you mean the wire that connects to the solenoid? I can take the starter out and take a look at it, but I don't think that should have become disconnected. Otherwise the only wires I know of that go to the starter are the ground wire and the positive cable. So.. which wire do you mean?
Hi all, I have a 1999 OBW with a 5 speed, and I just finished doing a transmission job on it... or so I thought. When I went to turn the key, I got no start and no crank. All that happens is a click in the cabin that sounds like a relay and a slight whir from the power steering pump. The starter motor shows the same voltage as the battery, but there is no change in voltage from either the battery terminals or the starter terminals when the key is turned. Things I have checked so far: -Neutral Switch and Reverse Switch connected -Transmission ground connected -Starter Motor appears to be connected correctly, with the negative on the bolt and the postive on the copper nut. -Battery has a healthy voltage (The multimeter wouldn't read it correctly, but we compared it to a good battery and it was identical) -Neutral Switch shows continuity in gear, and infinite resistance in neutral (which is contrary to what the Haynes Manual says should be correct? I *did* try starting it in gear instead to see if the logic was somehow reversed on the switch, but that had the exact same result) -Reverse Switch shows continuity in reverse, and infinite resistance elsewhere (which is what the Haynes Manual says is correct) -I did visually check the clutch switch on the pedal, and it appears to be functioning normally (it was also working before I did any work on the car, and is nowhere near the work that I did to the car.) Possible Related thoughts: -A few hours before I attempted starting the car, I attached it to a wall charger as it had been disconnected for almost a month. The charger was 12V 6A. -When filling the transmission with gear oil, a decent quantity of it spilled in the engine bay due to the pump I was using to fill it having a hose come off. I did clean up as best as I could. (Perhaps a short somewhere?) Any help and/or thoughts are appreciated Thanks!
Actually, scratch that. I took at look on the car side of things and only one of the connectors is gold there, being the black wire, #3 on the diagram. I think the yellowred is actually the ground connection for the heater? Edit: I found a pinout for the ECU. Pin 23 on the ECU is for the sensor, and pin 38 is for the heater, so the black wire on my sensor should theoretically go to the black wire on my car and the two white wires should go to either of the other two wires. I'll do that and it hopefully won't throw a code. Thanks for the help!
So I managed to find the wiring diagram for the sensor at this link http://ww2.justanswer.com/uploads/Barlogio/2010-11-27_160852_leg113a.png What I am wondering about now is which wires go to where on the sensor side of things. The sensor itself has two white wires and one black wire, with the black wire having gold on it as Fairtax4me mentioned. From what I've read, Fairtax4me is right about the two white wires being heater wires and being interchangable, so I want to know where the black wire goes. I'm not very good at reading wiring diagrams, am I right in thinking that the yellowred wire is the sensor wire in this case?
Hi all, I have a 1999 California spec OBW, and I've got an issue with the connector on its front O2 sensor. In taking off the exhaust in order to remove the transmission, I accidentally let it drop before I had disconnected the O2 sensors. The rear sensor was fine, but on the front sensor, the metal prongs slid out of the plastic clip that held them in. (Pictures below) What I need to know is in which orientation to reattach the prongs to the plastic clip. Has anyone else had this happen to them that might know which way around it goes? (It matters because the plastic clip, though a symmetrical triangle, has the pinch clip thing on one side of it and thus only goes in one way.) If not, does anyone perhaps have a pinout for that O2 sensor? Thanks!
Hi all, I'm taking my transmission out in a few weeks because the diff is grinding around corners, and I'm currently searching for a replacement unit. I'm wondering about the compatibility of various transmissions with a 99 OBW. Having read into transmission swaps a little, it's my impression that many of the units end up being compatible with the only potential complication being that you might need to swap the rear diff if the ratio is different. Taking a look at this chart, Www.gearhack.com/myink/ViewPage.php?file=docs/Subaru+Transmission+Chart I see that, for example, the GT transmission for 99 is the same, with the exception of having a lower 5th gear (which actually seems like it'd help with highway mpg) Am I right in thinking that there wouldn't be an issue with using that transmission in my OBW because the diffs are the same, or are there other complications?
